SOURCE: need to remove dell e193fpc flat panel covers to repair
First remove the stand. Then at the bottom of the monitor there are two small openings an inch or two from each edge. Starting there with WIDE flat blade screw driver (or a couple of them) it IS possible to pop the catches that hold the back of the case to the front. You have to go around the case very carefully popping each catch and preventing the areas you have opened from becoming re-latched. I found some wood popsicle sticks good for that.
If you search for "LCD Monitor Repair" you can find sites that have video's of several Dell models (but not this exact one) any that use the "pop open" case are pretty much similar.
One note after you get inside. The power supply board had the WORST solder job I have seen in a long time. The failure in the unit I repaired was due to open solder joints on the hi-voltage transformers taking out the power transistor's that drove them. It took me two months, but I found some replacement transistors on ebay and after resoldering many of the joints on the board it the monitor works fine.
I attribute part of the failure to the use of Lead free solder which is becoming common in all consumer electronics. It makes for brittle connections that fail easily and there is also the issue of tin whisker growth that will hit in a few years down the road.
