The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&*(
I do have the same problem with my washer, however in my case the basket spins freely, how can i fix a wiring failure?I do have the same problem with my washer, however in my case the basket spins freely, how can i fix a wiring failure?
You can't post conmments that contain an email address.
Hi, the F50 error code is a stalled motor error. There is a part called a "Rotor Position Sensor" that sees the motor running.This error will display if it faulty..
The F50 error code is a stalled motor error.There is a part called a "Rotor Position Sensor" that sees the motor running.This error will display if it does not see motor movement during a cycle.You want to make sure that the spin basket turn freely.Turn the basket by hand and it should turn freely.If it does not turn freely then it could cause the F50 error.If the basket turns freely then the problem is most likely the main control or the Rotor Position Sensor has failed.I recommend having a technician to check this problem.
The F50 error code is a stalled motor error. There is a part called a "Rotor Position Sensor" that sees the motor running. This error will display if it does not see motor movement during a cycle.This is a repair I recommend a technician do but there is one thing you can check. You want to make sure that the spin basket turn freely. turn the basket by hand and it should turn freely. If it does not turn freely then it could cause the F50 error. If the basket turns freely then the problem is most likely the main control or the Rotor Position Sensor has failed. I recommend having a technician check this problem.
Unfortunately it is not so easy. F50 is the code displayed when the fault persists in the RPS ( Rotatory Position Sensor ). You have to replace it. The problem may be a burnt CU ( Control Board ). It can also be an indication of motor being stalled. Thank you Sir, Have a nice day.
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
