I got a refurbished computer and do not know how to connect the external speakers I bought. I need a diagram or details on how to connect the speakers.
Monitors seldom have sound. This one of yours is little known as I am trying to find the specs on it. Sometimes they have an audio socket, but you have to run a cable to powered speakers. The data signal from a computer sound card is not amplified, it is just data.
you can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
Carlos, I just bought an LCD tv too. To connect external speakers to mine I had to buy some high end 5 channel pc speakers and connect them through the headphone jack(I know how stupid that sounds considering we spend $1000.00 on a TV and thats my only option for external speakers.I looked at your owners manual and didn't see a headphone jack though so you may have to opt for speakers that plug in with through the usb port. Some new tvs won't support external speakers unless you use complete home theater surround sound system which will connect through the rca cables (red,white)
If you have a external speaker try to connect the external speaker and check how the sound works on the external one.. If it works well then the internal speakers have gone bad.. Contact the computer manufacturer to replace them.. If the sound plays scratchy in the external on then unistall the drivers from the device manager and reinstall a fresh copy from the support website of the computer manufacturer.. If you dont have a external speaker better reinstall drivers if the issue is not fixed contact the computer manufacturer....
Monitors that do not have built-in speakers will not have an audio input.
Just purchase a set of external powered speakers and connect it to the audio output on the computer and place a speaker of each side of the monitor.
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
There are quite a few speakers on the market of different sound quality.
I sugest you get speakers that have a built-in amplifier and you connect the powered speakers into the headphone socket on the laptop.
Take you laptop to a computer shop with a CD and or DVD and test it with various speakers and then select one that suits your tastes and budget.
For your monitor with built in speakers, there should be a cable usually the plug is green in color, coming from the monitor which needs to be plugged to the back of the computer for the speakers to work. If you don't see a cable, then there is a plug on the monitor where a cable would go.
Yes you can connect external speakers. They plug into the back of the computer. There are usually round ports on the back colored blue, pink, and green. Figure: http://www.ultimatepcrepair.com/files/bsound.jpg (sometimes there is more, depending on your computer) The speaker cable plugs into the Green color one.
You need to check that all the speakers wires are connected! It might be due to improper connections! This cause an resistance! And hence due to this the sound may be less or distorted. Check all the connections!
