You may find the leak coming from the door seal or the soap drawer while it is filling,if you leen the machine back you will find two T20 screws under the front.you can get the book from asko.com.au
Testimonial: "Thanks a bunch, i needed a place to start and that helps alot."
I have the same issue with water pooling at bottom right corner and I believe the problem is a plugged drain. If you remove the dispensor drawer there is a little trough that captures excess water and drains. My drain is plugged. What is the best way to clean it out? How do you take it apart to expose the channel? Anyone know?
