This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash) - Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver) . My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
