LG W1934S-BN 19" Monitor Logo
Posted on Jun 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi everyone , ive got a LG Flatron monitor model number W1934S the problem im having with it is i keep getting a black screen with the power light still on, but if i unplug the monitor lead and plug in back in i a get a picture for a moment then it goes back to a black screen, everytime i unplug the cable and plug it back in the picture is there but only stays on for a second then its back to the black screen
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jun 15, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366126
Points
33650
Check out for bad caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
2helpful
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
My LG Flatron W1934S screen is now blank - the power light is blinking on and off, but no picture.
There is no problem with monitor, there is no signal from your VGA card, looking for a problem in your case.
2helpful
I want lg flatron w1934s drivers.please tell me how can i search them.
Hi, i would search on DriverGuide.com.... its the safest place. Most other driver download
sites are infested with pests that can bug you to no end.
Hello, I have a LG Flatron W1934S screen. When I switch on my computer the screen comes up blue light at switch but then turns yellow and with "digital power saving mode" screen goes blank. The...
Try it with another PC first just to be sure it is not video card problem.
More likely that it has dying power supply due to bad caps with leaking/bulging tops a shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/LG%20W1934S/
You should replace them in a set.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
My LG flatron monitor just blinking from wide screen then to a smaller screen then it stops for a while then after 5 minutes its gone my monitor doest show or the power does'nt show even if I keep on...
Hi it could be the video card in your computer is going bad slowly or your monitor has a faulty,you should try connect a different monitor to see if the problem id still there if still there this mean the video card is going bad
2helpful
LG FLATRON W1934S
hi,
check first if the connector has no connector pins wha are broken or shifted. if not chack cable for hard nobs or turns maybe cable is interrupted.
take other schreen to check VGA output of PC.
if all this not helps mail me back
greetings cis
1helpful
My lg flatron model w1934s was working fine but now it will not come out of power saving mode at all. What should I do?
Try turning it off and hold the power switch in for about a 30 seconds. This may help to reset the monitor. Afterwards, try and power it up again.
2answers
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
