Kenmore Dryer light comes on but control panel not operating
My Kenmore Dryer light comes on in the inside when the door is open, but the control panel does not operate (will not light for me to activiate dryer). There is a clicking noise that comes from the control panel like something is trying to work. I unpluged one of the wires from the harness that is connected to the control panel and the clicking noise stopped but the panel still does not work still. Should I replace the control panel or buy a new harness?
hello there: If you dryers light works but the dryer will not start usually the door switch is to blame Your
dryer can't operate at all if the door switch is defective. It's inside
the dryer main housing near the door frame. Sometimes you need to raise
or open the top or front of the dryer to reach the switch. If it's
defective, you need to replace it.
Door switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
The control board is bad. You will have to replace it. You might aslo theck the fuse, sometimes they look a little different than you are used to. Refer to your owners manual and wiring diagram to find it. You can also find more info on the Whirlpool website. Whirlpool makes Kenmore.
unplug dryer, then take the top off and check your connections to door switch.i believe this model has a broke belt switch.open the bottom with the machine unplugged and reach inside and see if the belt is broke.if it is then replace the belt.
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is. InMrFixIt
Front Panel lights not working? Dryer inside light does work? I fixed this twice already on my dryer. Please read this whole explanation
I live in New Orleans where the humidity is very high. I have a laundry room where my Washer and Dryer reside. Kenmore HE4T. I noticed that when I shut the laundry room door, my central A/C pulls hot air from outside the house via the dryer exhaust duct. This causes moisture to build on the inside of the dryer and especially the front control panel. Did you ever see moisture on your dryer?s door even when there were no clothes in it? The moisture collects on the Silicon board that controls the dyers function and basically causes a short.
This is what I do to fix it. You will need a ¼ nut driver or socket.
1. Confirm that you have power to the dryer <- is the inside dryer light on when you open the door. YES- keep reading.. NO ? find the circuit breaker and reset it.
2. UNPUG THE DRYER! ! ! ! ! ! ! !
3. Find the 3 screws in the back of the dryer that hold the dryer lid on. Unscrew them and slid the lid back and lift off. Is there moisture on the inside of the lid?
4. Find the 2 screws that hold down the front control panel. They should be silver and will be on top. Do not remove the inside gold screws.
5. Find the 3 screws that hold down the power control panel on the top left side of the dryer. Probably has a high voltage warning sticker on it.
6. Lift the power control panel (sheet metal) part and move it to the right so it lays on the dyers drum. There are some wires attached to it and unless you are a very handy person, I wouldn?t remove them.
7. Lift the front control panel straight up until it comes out of the dryer. There should be some wires that attach this piece to the power control panel. If you are handy, you can remove these 2 clip-on wires from the power control panel by squeezing the black connector locking clip and releasing it from the panel.
8. If you flip the control panel around you may notice moisture on the green silicon chips. Get a hairdryer and take your time to dry them.
9. Dry all components of the dryer with a hairdryer.
10. Put everything back together except for the lid and all the screws. Remember that the front control panel slides down first and then the power control panel sits on top second. Plug the dryer in and see if you get lights, but don?t start the dryer. Unplug the dryer and replace all the screws and the lid.
The problem is that once the dryer gets wet from the moisture, it never dries enough for it to start working again. This is a bad design from Sears/Whirlpool. I learn my lesson that just because its more expensive doesn?t make it more better.
I now keep my dryer and washer door open all the time even when there are no clothes in it. This lets the moisture escape into the house rather than collect in the dryer.
I hope this helps at least one person.
Thanks
Jason Kennedy from New Orleans
Kenmore 417.84082500
