Batteries go bad, ports go bad (especially on casio phones) but the actual wall charger can go bad as well. If it is the port, a cradle/dock charger will work..if it will not charge in the car either..it is your port
Hi, you can check with another charger first to know exactly what the problem really is before you can take the next step .Also check the phone on another charger.
After checking with another charger, if charger work,that means the charging sport where you plug in the charger is not working and need to be replaced.
If when you check the charger with another phone and and the charger doesn't work, replace charger.
Take care.
SOURCE: will not charge
It could be that the battery is bad. Bring your phone in to any repair shop and try using another battery. Most cellphone shops or stores has a test battery.
If you couldn't find a test battery, refer to a cellphone tech to test if the battery is still okay.
SOURCE: my casio gz boulder phone
Hi, it's a common known problem that this phone's internal charging system FAILS after about 4-12 months...I have to literally tie a rubber band to the charger's "line" while the phone is being charged to get it to work. (You know--when the red light comes on it's charging--so you have to get the charger line in a certain place & keep it there so it will work.) A real pain in the ***--I'm 17 days from an upgrade--which sux, because I like this phone other than this. Of course, verizon no longer sells it--probably for this very reason. Good luck & just keep the phone as "still" as you can when it's charging. Oh, and I have the charger cradle--that was the first thing to GO as far as charging. I WON'T WORK AT ALL....
