the reason the player is not loading a disc is either the lens is weak or dirty.
Try to use a lens cleaner to clean the player.
If it does not work, then you have to replace the lens because it is very weak.
To fix it if the weak lens, open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
Take care
The lens from the reading head is dirty to clean it you go 2 ways;
1 - easy one - not always efficient: use one of those special cleaning disks.
2 - hard way - most chances of success: remove the case and access the mechanism, use a can of compressed air to blow away all the loose dirt (be thorough especially under the lens) then use a q-tip to gently wipe the lens.
