Question about Dmm Vision Fitness T9500 Treadmill
I have the Vision Fitness treadmilll #T9450. When
I have the Vision Fitness treadmilll #T9450. When turned on the screen will light up and beep, but the belt won't move. It hasn't been used very much, but I've had it for 3 years.
    New Friend:
    Problem Solver:
  • 8 Answers
Try replacement of the mains power cable.
They are of poor quality from new.
Only then should you test and replace other components.
The mains power cables are a common problem with folding vision fitness treadmills
Posted on Mar 04, 2019
    New Friend:
  • 26 Answers
Take the front cover off and see if the drive belt is on the motor. Try running it to see if the motor turns. This could be a motor or controller board problem.
Posted on Jun 16, 2010
6ya staff
SOURCE:
How do I fix E5 error on my Vision Fitness T9450 treadmiill
The primary cause of E5 is the elevation system malfunction - Elevation error (signal lost)
First check all wires from the elevation motor to the lower motor control board. Also check the main wiring harness from the console to the lower motor controller to determine if a wire has been cut, pinched or shorted to ground.
If all wiring is in perfect condition and the unit has not been recently moved, dismantled/reassembled, then there might be a failure of the lift motor itself, or in some cases the motor control board (controller)
Nov 26, 2013 | Vision Fitness Exercise & Fitness
My Vision Fitness T9450 is having a power issue. I plug it in, turn on the power button in the back, the console lights up as normal. Then when I press start the power goes out before the belt even st
you have a SHORT circuit maybe in the power supply, transform, capacitor, motor or lower board.
You must call some tech qualified, for to fix it.
see the block diagram.
God bless you
Sep 19, 2012 | Exercise & Fitness
Some of the Vision Fitness t9450 treadmill incline and speed quick keys stopped working along with the manual speed and incline buttons
It sounds like you have a membrane issue. There are a number of different T9450 models and they all have slightly different consoles. You'll need your serial number to help pinpoint the parts you need. Your best bet is to go through the manufacturer (johnsonfit.com) and have them help you get the correct membrane and overlay.
Jun 08, 2017 | Dmm Vision Fitness T9500 Treadmill
Hello im getting a startup error when i press the quickstart button on my 95ti treadmill.
when I start up my treadmilll across the screens reads Motor-comm error. what coulld be the problem.I keep it clean and dirt free.
May 03, 2011 | Life Fitness 95Ti Treadmill 95 Ti
I am an Electronics Technician but have never worked on a Treadmill. Do you have any tips on removing the console and getting to the membrane keypad? Vision Fitness T9450 The buttons on the touch pad...
look at your manual for the blow out picture remove the rite screws and have some one help you hold the console while you disconnect the wire harness
Feb 26, 2011 | Exercise & Fitness
I have a vision fitness T9450 treadmill. My wife was using it and it slowed to 2mph. That is all the faster it goes now. Elevation controls work fine and everything else functions.
first thing to do is to enter the calibration mode. First remove and replace the safety key. Press and hold the elevation up and the speed down buttons until the machines beeps at you 3 times consecutively. You should also see either the model "9450" or the software code which varies from machine to machine. You should now see one of two things - "eng1" may be displayed in which case just use the elevation keys to get to "eng4" and hold enter for 3 seconds - then press start - this will calibrate your machine and confirm if there is any speed reading issues.
If your machine displays more numbers as it would on the deluxe and premier consoles of this brand then you should see the model of your treadmill at the top left. hold enter from here until "eng1" appears and the perform the steps as above. If the speed is not calculating properly during the calibration the magnet or the speed sensor may have been moved or the magnet could have gone bad - usually slowing to one speed and not changing is the sign of a bad speed sensor. If the control board had any irregular voltage it would shut down as a safety precaution.
Feb 06, 2010 | Dmm Vision Fitness T9500 Treadmill
Just bought a 9250 vision fitness treadmill and when we first plugged it in the screen stays blank?? What should we do?
First Your outlet to see if power is their, then check on/off switch usually their is an internal light in the switch to show power is to the switch then check the breaker button next power switch. these are a few things to look at. Check if the safety key in place on the upper console
Feb 01, 2010 | Dmm Vision Fitness T9500 Treadmill
Dmm Vision Fitness T9500 Treadmill Logo
1,293 people viewed this question
Top Dmm Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
