The most common thing on that washer to cause it not to spin would be your door lock assy. The second most common issue would probably be your control board. If it is not draining then it also will not spin so make sure the pump is working. If i had to guess I would assume you have a bad door lock but without diagnostics and a multimeter its impossible to know for sure. Hope this helps. _MJ_
