JVC model KD-S6060 car CD/radio. Have removed from car to get CD to eject. That now works fine but nothing else works. Have tried select/att,still nothing. Is there another procedure?
Some players get set to a default like when it was fresh out of the box when power is removed. Since you radio from the factory knows there is no disc in it, it thinks there is nothing to eject. Push the reset button and your disc should eject.
the code for this radio was not set by the factory, but by the original owner and the code could be anything-unfortunately unless you contact the original owner and they know the code you are out of luck
if the car battery had gone dead while it was in the garage you may have to press the reset button on the radio( if there is one, it would be behind the face and there will be raised print that says reset) if there is no reset button you can unplug the radio harness for about a minute or so to reset it.sometimes the fuse for the 12 volt ingnition can be the problem( on your radio it would be the fuse connected the red wire-if it is ejecting and giving you display the fuse connected to the yellow wire is good-
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
