Akai PDP42Z5TA 42 in. Plasma Television Logo
Posted on Apr 13, 2008
Akai PDP42Z5TA 42 in. Plasma base removal
I am trying to mount this tv on the wall but can not figure out how to remove the base. Any suggestions on how to where to look. The user manual does not discuss the issue.
Thanks
  • rsslaw Jun 16, 2008
    Same problem - our Akai PDP42Z5TA plasma tv is hangin on the wall but I cannot get the base off - I've removed ever screw I could find, but it still will not come off. Please help.
    Thanks.
  • Anonymous Nov 26, 2008
    how to remove my base off my plasma tv
Anonymous
Level 1:
Problem Solver:
  • Contributor 21 Answers
  • Posted on Dec 01, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
21
Questions
0
Helped
7815
Points
30
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
475
Points
I got it!!!!!
i just asemble my TV on the wall and it's pretty easy to remove the base.
there is 3 screws on the back of your tv. One is close to the botton (small screw). And the two others are hidden behind the support of the tv mount ( you will need to remove the support the comes with the tv mount to find these 2 screws) once you do that, the base comes out. ( you need to remove 3 screws on each side of the base.
Good luck!!!
My TV looks awesome on the wall.
Anonymous
Level 1:
  • Posted on Sep 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
475
Points
0
If you ever get the base off, I'd like to buy one.
2answers
Where is the cable input?
Most of the jacks including the cbl jack are mounted vertically under a lip towards the bottom (rear of coarse)
2helpful
Can you buy parts anywhere for the Akai TV's? I have a 42" plasma that needs a new mother board. Please help!
Rather than ebay or Akai directly, i would order parts from :-
http://www.shopjimmy.com
Thanks.
2helpful
Akai PDP42Z5TA
Back of an Akai PDP42Z5TA showing where the Power board is.
Akai 42 plasma controller can not be programed tried every code
i just had this same problem with my 42" akai plasma and after getting no help no where i finally figured it out on my own. The model i have is a PDP42Z5TA but my guess it will work with yours also.if your remote is like mine there should be a "set" button somewhere up at the the top.hold this down till the "tv" button goes solid red. with the tv on or off keep pressing the power button till the tv turns on or off( dont go too fast) or you can pass it up easily cause when the tv does turn on or off you have to hit enter to lock it in.
2answers
Screen will not appear
You have just found out why the plasma sets are fading from the market.
Both of you may have a power supply problem. The PS in plasma TVs is more complex than in LCD sets and therefore more likely to fail.
Since Akai is so poor on product support, they may not even have parts since that set was made by Samsung who also doesn't want to hear anything about them (their site doesn't recognize the Akai model number), you may be out of luck.
In researching Akai, I find large number of folks who will not buy any Akai anythings again.
This kind of performance is unusual for a Japanese company.
I need to remove the base from my 42 inch plasma TV to mount it onto a TV stand. How do you remove the base?
Good Day;
The base is attached by four, inset, allen screws on the back of the unit, bottom. The 'key' word is INSET (recessed).
Good Luck, Day, Big Irish.
2answers
Akai Plasma PDP42Z5TA - removing base stand
The base removes with the support arms that rise the height of the tv. remove all the screws from the back of the support arms and the base will slide out with the arms. you will need the holes open to mount to the wall mount
7helpful
Remove tv from wall mount
there is an anti theft device on the wall mounts you need the manual to adjust mount to take off
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=255670bad135aec3653b726b698def9d&q=Samsung+PDP4294
heres the link just follow instructions to get download i will also be posting it here on fixya too
this the manual
HELP PLEASE!!!!!
There are two handles on this set that come off with the removal of two screws. The base has posts that slide in up from the bottom. Trace the legs up and remove the two screws that hold each leg. You need a second person to help lift the set from the base. Now mount to the wall bracket.
Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
