Question about LG WM-2277HW Front Load Washer
Washer has water still in drum and OE on digital readout
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 17, 2010
    New Friend:
  • 161 Answers
Check your filter it may be clogged.
http://www.whitegoodshelp.co.uk/wordpress/lg-washing-machine-error-code-oe/
6ya staff
SOURCE:
I have standing water in drum every morning.
Without further information, I can offer three possible issues:
1. The fill value is furred up and is not fully closing (diagnose this by turning off the water after use at the isolator valve - and if no water is getting into the drum overnight, then it is a filling problem and you needn't read on - as opposed to a draining problem in which case read on!)
2. If you have a long drain hose running along the back of kitchen units, perhaps it is running back into the machine
3. Have you installed anything else into the same drainage pipes - such as a waste disposal unit or another appliance - that may be pushing water down the drain so fast, that some returns into other connected appliances?
Good luck
Sep 20, 2014 | LG Wm2688hnma Front Load Washer wm2688hnma
WF203ANW OE Code..still
I had a piece of rubber stuck round the actual pump very hard to see had to take pump out and clean it totally
May 23, 2013 | Samsung WF203ANW Front Load Washer
Dryer does not spin dry, water left in drum...Error code OE
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
May 02, 2011 | LG Dryers
Lg wahser wm1832cw flashes oe on readout. nothing in drain
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Aug 25, 2010 | LG WM-1832C Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
We are getting a sound that the pump is running but no water in entering the drum and we are getting a FH signal readout. we have followed the troubleshooting booklet. Is it possible the pump is bad?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Aug 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Lg frontload wash
I removed the top panel of washer(4 screws and slide). Then found the small 1/4" hose that goes from drum to drain hose to be pluged with goo. I cleaned inside of hose and washer worked fine.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Washing displaying OE error code
here's a link to a service manual for you particular model seems OE is an overflow error, this will help you trouble shoot your problem. ( im current ly downloading this manual for my own reference )
http://www.servicematters.com/maytag_library/docs/16026186.pdf
Mar 24, 2008 | Maytag MAH6700AWW Neptune Front-Load...
LG WM-2277HW Front Load Washer Logo
673 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
