Question about Sony Bravia KDL-37M4000 37 in. LCD HDTV
Tv turns off after playing 15-20 minutes, then it will shut down more often. the timer/pic. off button flashes six times. thank You.
  • 10,594 Answers
6 times power/ standby light blink error shows problem of back light inverter board in your Sony KDL-37M4000 tv as per mentioned in related service manual.
Check back light inverter board to fix the issue.
Thanks.
Posted on Jun 17, 2010
    New Friend:
So maybe my tv has the same problem,,it powers on ,then it say bravia,,the 3-5 sec turns off,,so i guess is the power supply?
thanks
Posted on Jul 25, 2010
  • Anonymous Jul 25, 2010
    so maybe my tv has the same problem,,it powers on ,then it say bravia,,the 3-5 sec turns off,,so i guess is the power supply?
    thanks
  • Sony Master
  • 8,457 Answers
The power supply board is the cause,take the tv aparts.Replaced the power supply board,that the board where the a/c power cord plug into.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
  • Sony Master
  • 3,866 Answers
Common issue in bravia line when the filler caps are swollen on the power supply the unti will shut down. the remedy is repair, the cost could range , ball park $150..
Issue bas filler caps on the power supply due to heat,dust or debris in the unit.
thanks and please do not shoot the messenger and leave a postive rating and feedback thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
  • Sony Master
  • 778 Answers
First test the power board to make sure that's where the problem is.
Then, if you have to, buy a new board or have yours serviced.
For more instructions check the following links:
http://www.ebay.com/itm/DELTA-DPS-250AP-34-1-474-095-12-SONY-KDL-42V4100-REPAIR-SERVICE-/110745604426?pt=LH_DefaultDomain_0&hash=item19c8f3d14a
or
http://blog.coppelltvrepair.com
Posted on Sep 17, 2011
Anonymous
SOURCE:
Sound goes off after 15 Min
Assuming it is not hardware but soft settings...
1) Check and make sure that your TV does not have the timer set.
The Timer feature allows you to set a day and time for the TV to turn on automatically and the device and channel to display when it switches on. If the TV is already on at the requested time, the TV automatically tunes to the channel you designated in the Timer menu.
When the Timer turns on the TV, the following message is displayed: "Press a button for the TV to stay on." Press any button on the remote control within five minutes if you wish the TV to remain on.
Note: The TV clock must be set before you can use the
Timer feature (see preceding page to set the clock).
On/Off
Press down arrow / up arrow to enable or disable the Timer.
2) If not working, try SYSTEM RESET. Press SYSTEM RESET button on the front panel with pointed object (e.g. straight paperclip). TV turns off, green LED flashes for about 1 minute. When it stops flashing turn the TV on again. All settings other than Parental Lock need to be set again using the manual.
3) TV RESET. If all else fails for soft error. Your manual describes this last resort for soft type error. It could be hardware problem needing more expertise.
Manual can be viewed on a computer at
http://www.audiolabga.com/pdf/V32-V32L_Service_Manual.pdf
Aug 05, 2014 | Mitsubishi WD-62531 Projection Television
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How to reset lamp timer on panasonic pt-52lcx16
Turn On tv, press and hold Volume Down button on TV Front and Play/Split button on Remote at same time for six seconds to reset lamp timer.
TV screen will show lamp timer reset display upon successful process.
Jun 26, 2010 | Panasonic PT-52LCX65 44" HDTV
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    On and off
    That hapened to me once and the solution that worked for me was unpluging the TV for about 5 minutes and pluging it back in, you may just need a new remote though.
    Jul 28, 2008 | Philips 55PP9352 55" Projection Television
    TV Won't power on
    Replace the capacitors in the DM board or the lamp is defective.
    Sep 18, 2007 | Mitsubishi WD-62327 62" Rear Projection...
    Sony Trinitron Kv24Fv12
    stand by timer light flashes 7 times no pic no sound. how do i
    stop timer
    Apr 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
    Sony Bravia KDL-37M4000 37 in. LCD HDTV Logo
    638 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Ekse
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
