Televison & Video Logo
Anonymous Posted on Jun 17, 2010
I have broken two of the bolt fittings on the back of the t.v trying to attach a wall mount bracket. two of the four bolt fittings have fallen into the t.v now ??? How do i safely get them out and fix them back in place so the t.v can be wall mounted again
Anonymous
Level 1:
  • Contributor 26 Answers
  • Posted on Jun 17, 2010
Anonymous
Contributor
Level 1:
Answers
26
Questions
0
Helped
4392
Points
71
UNPLUG SET. Lay set flat on a blanket and remove all the cabinet screws. The back will come off and you can search for the nuts. If they won't go back in place then at least don't leave them in the set. A strip of duct tape will hold them in place and shouldn't interfere with the bolt.
Testimonial: "Thank you for your advice, i will try and get back to you if possible as i think i have caused enough problems for one day......"
1993 electra glide front faring removal
1993/1994 Outer Fairing and Windshield for FLHTC, and FLHTC ULTRA
Removal
First remove the headlight assembly and the bolts, nut and the washers attaching the outer fairing piece to the windshield and inner fairing piece. THEN loosen the four bolts attaching the light bracket and the outer fairing piece to the fork brackets. Remove the upper bolts but leave the lower ones in place. Cover the fender. THEN rest the lower light bracket onto the fender. THEN remove the fastener securing the headlamp trim ring and remove the trim ring. THEN remove five screws that secure then headlamp assembly to the outer fairing and remove the headlamp assembly. THEN reach through the headlamp opening and loosen four locknuts on the two studs on each side of the headlight area which attach the fairing to the metal brackets inside the fairing. THEN remove the fairing by pulling it straight ahead away from the brackets.
Installation
First loosely position the outer fairing in place over the inner faring with the four studs going into the two brackets. Then install the five windshield fasteners through the outer fairing, the windshield and the inner fairing. THEN tighten the four stud nuts to secure the fairing to the brackets, being sure to have the inner and the outer fairing properly aligned at their outside edges. THEN position the light bracket so that the slots fit around the upper fork bracket bolts and thenalign the lower fork bracket mounting holes and replace the two lowering fairing mounting bolts through the light bracket and the outer fairing and the inner fairing and screw them into the lower fork bracket. THEN make sure that the rubber seal around the inner fairing is properly seated and not pinched and tighten the four fairing attachment bolts to 12-13 foot pounds (16 -19 Nm). THEN tighten the windshield screws to 4 inch pounds (0.45 Nm) but no more than this amount starting in the middle and working outwards on both sides. THEN reinstall the headlight assembly.
2answers
I cannot locate petrol filter on toyota corolla 160i gle 1997 model
Hello my friend,
the only petrol filter is fixed directly with the petrol pump under the back seat so if its need change you must change the petrol pump , or attach one directly near the engine...
5helpful
2answers
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
1helpful
2answers
The passanger mirror was broken and has fallen from the car. It is still hooked up to the power moter but I will need to by and install a new mirror because the bracket is broken. Please describe how to...
REMOVE THE MIRROR TRIM PANEL.THEN UNPLUG THE ELECTRICAL CONNECTOR FROM THE POWER MIRROR SWITCH.THEN REMOVE THE 3 RETAINING NUTS AND DETACH THE MIRROR FROM THE VECHICLE.
1helpful
3answers
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
2helpful
How do i attach a wall mount to the back of my 20" samsung?
Samsung wall mount bracket WMB 1900T adapts for four hole wall mounts. Fits 19" to 22" monitors. Price is $27-$42 at online stores.
1helpful
2answers
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
