Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Ricoh aficio 1515 printing faded images on one side. Just replaced the drum / toner / hot roller. Same issue when printing and copying What else could cause the problem?
  • mike_kozinet Jun 18, 2010
    Repost. Solutions is here:https://www.fixya.com/support/t3950047-ri...
  • Ken Adcock
    Ken Adcock Oct 26, 2017
    THE OPTICAL MIRRORS USUALLY THE THINNEST MIRROR OFTEN NEEDS CLEANING. LOOKING CLOSELY WITH A LIGHT YOU CAN USUALLY SEE A SMUDGE. THIS HAPPENS FREQUENTLY WITH ME ON CS 1620,2020 IF THEY ARE NEAR A WINDOW OR DUSTY ENVIRONMENT.
    New Friend:
  • 49 Answers
Could be caused by a dirty laser unit or a broken transfer roller bushing. Also check that all springs are on the transfer roller. Some technicians remove the springs to get rid of the clucking noise but don't realise it causes other problems.
Posted on Nov 20, 2017
  • 904 Answers
Could be one of a few things:
Most likely is the transfer roller. If it's dirty or old and not applying enough charge, it may not be pulling all the toner away from the drum. Replacing the transfer roller is easy if you can get a new one.
Are you sure you have the correct toner? The wrong toner can definitely cause copy quality problems.
If the springs that hold the press roller against the hot roller are not properly in place (or if they have started to lose tension) the toner won't be fully fused onto the paper.
I'd start with the transfer roller (black roller that sits opposite the drum on the right side door) first -- it's the most likely culprit.
Posted on Jun 19, 2010
6ya staff
SOURCE:
Part of printed copy is washed out ricoh aficio sp c210sf
Seems its fuser assembly fault.
Fuser assembly is a part to fix toner image permenentely with the help of hot rollers on media. The temparature varie depends on model, in case the temparature not reachess specified level you may get image fixation problem, the same what you are facing. Replace fuser assembly.
Oct 02, 2014 | Ricoh Aficio SP-C210SF Printer
Ricoh aficio 2075
R u using original toner? if no, replace ori. if yes, r the hot roller in the fuser hot enough? is there any gap between hot roller and pressure roller? toner smear can only be caused by non ori toner or faulty fuser unit. Faulty developer can cause sandy print out
Mar 22, 2014 | Ricoh Office Equipment & Supplies
Copy quality. every 20 sheets or so have dark marks.
Check (Fuser) Hot Roller its can be bad Hot roller.Clean Charge Roller and All Drum Unit. is it OEM Toner? if you can send me scan image I Can tell you what is the problem Exactly.
Jan 08, 2012 | Ricoh Aficio 2035 Copier
My Ricoh aficio 1515 printing and copying with background
If background is appearing on your copies, the problem is most likely the photoconductor unit (PCU) which houses both the drum and the developer. It comes as one piece, and you can easily remove the old one and slide the new one in.
The PCU is located to the right of the toner bottle, and the new PCU will come with instructions for replacement, but it is a simple procedure.
If you don't have a local dealer or supplier, you can purchase a PCU online just about anywhere that sells copier toner.
Aug 30, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
provavelmente o problema ? na porta lateral, no rolo de transfer?ncia, aquele rolinho preto no meio da tampa, ao tirar ele tem uma mola em cada lado, o lado da c?pia fraca est? com a mola com pouca press?o, estique um pouco a mola e coloque-a de volta, deve resolver...
Jul 09, 2010 | Ricoh Aficio CL3500N Laser Printer
RICOH AFICIO 1515 when printing/copying, comes out with a blured section on the left side (about 1.5 inces wide). I just replaced the drum. Same issue was with the old drum. What else could cause this...
Take you drumback out and lookinto the machine with a flashlight.
There should be a piece of glass that isolates the laser from the rest of the machine, check for dust or toner. Clean if necessary.
Jan 22, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 450 back side is dirty?
Problem on charge roller,Upper drum unite,please clean or change it then solve your problem.
With the best luck.
Jan 20, 2010 | Ricoh Aficio 450 Copier
RICOH AFICIO 401 COPIER- COPIES FADED ON ONE SIDE
Hello sir; You have to replace drum and developer meanwhile you have to clean up image roller, then it will take care the problem.
Nov 06, 2009 | Ricoh Aficio 450 Copier
Hello sir i have problem in ricoh aficio 1022 image repeat problem. u told me to change hotroller pressure roller baring also i change its same plz tell me where is the problem before fusing copy is ok...
Hi sir; No matter who told you to replace, the hot roller is the most possibility, the next item also last item you need to check is drum unit (drum cleaning blade,[replace it ], image transfer roller [clean up by alcohal] and drum [ depend condition ]).
May 09, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
398 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
