The English manual (Spanish is also available) for your D60 is available free od charge from Nikon below:
http://www.nikonusa.com/pdf/manuals/dslr/D60_en.pdf
The shutter on the D60 can be released by self timer or remote (and of course by the normal shutter button). You're interested in releasing the shutter via IR Remote. An explanation of the shutter release Modes are contained on a single page (Pg. 54) of the manual and should be reviewed before going to the next page. The use of the IR Remote Release Mode is detailed here. Briefly, it states:
"Highlight Release mode in the Quick settings display and select one of the following release modes..." <table of choices & graphics>
You could select either Self Timer (10 seconds), Delayed Remote (2 seconds) or Quick Response Remote, but you're interested in one of the last two methods. The shortcut "Self Timer / Fn" button mentioned is on the camera body - between the lens and directly in front of the "D60" badge.
I hope this helps!
I assume you're referring to the ML-L3 infrared remote?
Select Release Mode from the Quick settings display. Select Quick-response remote. This will make the camera take a picture when you press the button on the remote. Well, almost. The same focusing and exposure metering delays occur as if you'd pressed the shutter release button.
You can also use the Delayed remote mode for group pictures. This gives you two seconds to hide your hand behind your back before the camera takes the picture.
By default the D60 will time out after one minute if you don't press the button on the remote. Custom Setting #17 allows you to set a longer interval.
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
SOURCE: Have a Nikon D60 and after I take a photo, I get
You need to press the Disp/Display button to remove the settings on the display.
Testimonial: "Also had to use the multi selector to get rid of it. I now understand the process. Thanks"
SOURCE: wireless remote control
Select Release Mode from the Quick Settings display and choose one of the two remote modes. The Quick-response remote mode fires the shutter as soon as you press the button on the remote. The Delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.
For full details, look at the "Releasing the Shutter" section in your manual (page 54 in my copy).
