Could you please recheck for the model number. R134A is a reference to the coolant used in the freezer mechanism.
Orange is often a reference to the 'Fast Freeze' function being turned On. Green is showing the freezer unit is at the correct temperature. Red is warning the freezer is Too warm. Some freezers are fitted with an 'Economy' function where the freezer can be run at a lower power level when not used regularly such as when on holiday.
Could you comment below with more detailed photos of the back of the orange switch and any other bits with it. If the switch isn't broken It might just 'click' back in. I don't know without better images.
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Are you sure it is a standby light? Usually the orange light is showing you it is in fast freeze. Try switching the orange button off and monitor the temperature. The freezer should cycle on and off, not run continuously.
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
