Toshiba REGZA 47HL167 TV Logo
Anonymous Posted on Jun 19, 2010
Upon turning tv on after it's been off for a while i get two lines going from top to bottom of the screen. theres a line on the left side about 2 inches in from the left thats red and about 3 mm wide and theres a few on the right about the same distance in but they're thinner and spread apart but yellow in colour. after about 10 minutes these lines go restoring normal viewing. whats causing this and will this get worse as time goes on
  • Anonymous Jan 25, 2011
    thank you for the reply. i'll give it a go and post the result.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jan 17, 2011
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366076
Points
33650
I see you ask the questions in my repair guide.
First, this is LCD TV so it does not use the X and Y sustain (some people called them Vertica/Horizontal inverter, which is not the right term) like the PLASMA TV.
The problem can be the T-CON, main board.
I would suggest to clean and reseat the 4 ribbon cables between the panel and the T-CON board first.
http://www.shopjimmy.com/catalogsearch/result/?q=Toshiba+47HL167
Anonymous
Level 3:
President:
  • Master 1,099 Answers
  • Posted on Jun 19, 2010
Anonymous
Master
Level 3:
President:
Answers
1099
Questions
0
Helped
307261
Points
3433
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS HELP...
1helpful
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
1helpful
Toshiba 46xf355db upon start up there is a fuzy picture and lines
I believe that tv is about 10 years old. The best solution and probably most cost effective is to replace it.
Line in left side of screen
bad panel call mits has 2 year extended warraty for panel, need to call for authorized service center
1helpful
2answers
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
1helpful
2answers
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
