Hello:
I have a whirlpool LER4634JQ1 electric dryer the turns off after 10 minutes. Once it cools down I press the start button and the dryer resumes normally for another 10+- minutes. The motor is quiet makes no grinding noise as an indication of a possible motor or bearing problem. this seem to be a temperature shutoff issue. Can you point me the right direction?
Agree with you. Make sure the lint collector is clean and ditto for the vent. If it goes up to roof have to check it there also to make sure there are no obstructions whatsoever in vent line. Unit is turning off because it is overheating. If lint collector and vent is squeaky clean and unit blows out like crazy then the temp switch is opening up prematurely and might need replacement or jumping - your call. If you want to check for part go here Search Over 2 1 Million Appliance Parts
SOURCE: my whirlpool dryer model number LER4634JQ1 is not getting hot
You need a 30 amp breaker in my neck of the woods. South Alabama, US
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My Whirlpool Dryer LER4634JQ1 (no heat)
most likely a thermostat that has failed, I'm having same problem and am just now learning how to test. research " testing dryer thermostats and fuses online"
