Microsoft Windows XP Professional Logo
Anonymous Posted on Jun 19, 2010
My DVD player can't detect DVD CD file, but it can play CD. i've tried to check on the device manager and its working properly. i also have tried reinstalling its driver but still not working... i am using samsung DVD/RW combo drive in windows XP professional SP2.
Anonymous
Level 2:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 78 Answers
  • Posted on Jun 21, 2010
Anonymous
Expert
Level 2:
Teacher:
Answers
78
Questions
0
Helped
15151
Points
273
I have faced this problem in my case DVD was working and cd not you problem is the lens of you cd/dvd drive has become worst and cant work any longer it needs to be replaced. Hopefully it might have helped you.
Testimonial: "Really, thankx bro... i think you are right... i will buy a new one... :) & see if its okay."
  • Anonymous Jun 28, 2010
    Thanks dude
Dell OptiPlex 780 with Windows 7 does not play my cd's or dvd's and is missing from device manager
Sounds like a problem of non-detection by the system. If the drive is missing from My Computer then it definitely is a non-detection issue. Try using this file (it's an exe when unzipped) and only required double-clicking.
http://www.geekstogo.com/forum/files/file/8-cdgone/
2answers
HP Slimline s3500f, Vista 64-bit. CD/DVD stopped working. I've reloaded the driver several times. Device manager says it is working properly. I have removed upper and lower filters in registry, I have...
A couple of suggestions.
1) Download HP Support Assistant to check for updates on your machine
2) I assume you are using Windows Media Player. Try another free program like VLC. Its handy to have 2 installed so you can toggle between the 2 if one is having problems.
My drive wont read anything. I am trying to install MS office from a DVD. my device manager says it's working properly and I tried the Microsoft Fixit and that didn't work
Device Manager states that it is working properly because it is detected by the computer. However, device manager has no capability of check if there's a problem with the lense of the DVD Drive. You can try a diffent CD to check if the problem is with the MS office CD or with the drive. If the DVD Drive still cant read any other disk it only means that it has a bad lense and you need to replace the DVD Drive.
Thanks for using Fixya.
2answers
My DVD player on my acer will not play cd/dvd..I downloaded a new updated driver--and now it plays cd --but still will not play dvd.
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no _ for your specific area
hope this helps
Same problem
oh my frd...it happens bcoz u could hav burned u r cd in data files format...wch will not detected by the cd player...cd player detects only the mp3 formats...so nxt tym u burn a cd check whether the option wch u given s mp3 format for audio files...and main thing is that check whther u burned a CD or DVD...bcoz CD player will not detect DVD...a DVD player can detect CD whereas CD player cant detect DVD disc my frd!!!!
2answers
2answers
PC IS NOT RUNNING ANY CD/DVD'S
okay try this
Go to your My computer icon--right click on it
properties-->hardware-->device manager
Find ur cd/dvd drive on it
Uninstall it by right clicking it (dont get scared ur system will detect it itself in next reboot and u dont need any drivers for it)
hope it will works if there is no physical damage
Please Rate ...
2answers
How
Hi there, if its what I think it is this is a common problem. In order for Windows media player to play DVD it needs whats called a codec. Try install a demo of win dvd and try it then, if it works you need to download a dvd codec pack. Use google or another search engine to find them on the net. Good Luck ;)
2answers
Both drives not recognising disks
Have an LG Super Multi DVD Drive, Model:GSA-4120B.
Won't recognize any disk, CD or DVD and won't play any audio video
Device manager says, it's working properly
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
