Had to replace transmission and now drill is stuck in hammer mode. I think problem is in section in front of the transmission. Have taken it apart (as far as it goes without removing bearings) and can't see anything wrong. Any suggestions??
SOURCE: Dewalt dw997 drill clutch stuck
your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
SOURCE: Dewalt 25900 Hammer Drill Won't hold a bit.
Yes there is I looked and the model number posted is a demolition hammer, so you might want to recheck before checking, but go to Dewaltservicenet.com and in the middle of the page it will ask you for parts or below that manual, go to manual and type in your model number and you will get an explosion and current pricing for this tool. Let me know if I can help I work on their demolition hammer on occasion. Good luck
SOURCE: dewalt xrp 18 volt hammerdrill. Need gear schematics.
Go to Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will take you to a page where the schematics are.
SOURCE: Dewalt drill. I have a stuck chuck.
Hi there.
spray some oil into it and tap it lightly with a small hammer. Then hold the chuck and gently squeese the trigger in forward setting and backward setting. Do not use full force on backward setting.
This should do the trick.
Iceman.
SOURCE: Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Testimonial: "Thanks for your help! It looks like there is still some live left on the brushes...I guess I was just overly concerned! :)"
I am assuming you are talking about
not being able to move the "Mode Control Collar" and unless you can
get it out of hammer mode, you will not be able to change the torque collar
either.
If you feel comfortable taking it
apart AND its no longer under warranty, my best guess without seeing the tool will
be part# N026313 Gear Case Assembly. It costs about $80.00 US
Hopefully its under warranty, if so
you can go to
http://servicenet.dewalt.com/ServiceCenter/Search
to locate nearest service center.
Good luck
Sorry I wasn
