The AquaSport watch? The one with the digital panel instead of hands? Push and hold the bottom right button (Reset) to get to the start of the menu. Use the bottom left to advance the modes and the ST/STP upper right button to change a display, such as time.
Truly unintuitive, but fun watch. If you're a masochist.
Hope this will helped you fixing the time of your Citezen divers watch. Just foolow the instruction below.
Change your Citizen watch's time zone without actually moving the clock hands. On the digital display, change the city that displays on the watch, which sets the time to the different time zone. The Citizen also has a calendar, timer, chronograph and LED lights. Since it is an Eco Drive watch, it is solar powered so you never have to replace the batteries unless its backup power source dies.
Difficulty: Easy
Instructions
Pull the setting knob (crown) out one "tick" for setting mode.
Set the mode hand to "WT-S."
Pull the crown out one more "tick."
Press the top button on the right side of the watch for the city setting mode.
Press the lower button on the right side to "SET" the city.
Turn the crown to select a different city, which changes the time zone.
Push the crown all the way back in to finish setting the time.
Thank you for using Fixya.
