Based upon your description, the drain pump has either failed or the
pump filter has become clogged.
To check the pump, remove the bottom
access panel. There you will find access to the pump
clean-out.(Large,white screw cap) Take care of lot of water going to the floor, unscrew the pump clean-out, catching and
discarding the water. When the water flow finally stops, completely
remove the clean-out filter. Inspect the clean-out filter, the drain
hose from the tub as well as inside the pump impeller for any additional
debris.
http://www.fixya.com/support/r615268-f02...
Check the above link for an detailed answer for one of our senior experts...
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Long Drain
