This is an analog & digital watch. Digital part of watch works great but the analog part is 2 min. slow and will not set. I have changed time zones to force reset always stays 2 min. slow.
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Set the time ahead of the actual time then put it near a strong magnet to stop the analog mechanism and take it away when you get to the time you want.
This is the craziest thing, never have another one.
Works, thanks
See the manual.
press de ADJ Mode button six times. You must see HS on the display. Press ADJ button. With LIGHT and STAR/STOP buttons you can adjust the analogic hour.
my watch shows 5 min time difference in digital and analog
Answer should read: 1) Press ADJ button six times. You must see HS on the display. 2) Press ADJ button until current digital time starts to flash. 3) Using the LIGHT button (-) or the RECEIVE button (+) you can adjust the analog time in 20 second intervals.
Answer should read: 1) Press MODE button six times. You must see HS on the display. 2) Press ADJ button until current digital time starts to flash. 3) Using the LIGHT button (-) or the RECEIVE button (+) you can adjust the analog time in 20 second intervals.
CORRECTING ERROR IN STEP 1
impostazione lancette
how to sycronize 2nd time zone analog and digital on tag h cl1110
