Insignia NS-BRDVD Blu-Ray Player Logo
Posted on Jun 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i connect my insignia blu ray player to my zoom wireless internet?
Anonymous
Level 2:
Champion:
  • Expert 312 Answers
  • Posted on Jul 01, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
312
Questions
0
Helped
126410
Points
418
This model (NS-BRDVD) is not wireless capable.
How can I connect my blue ray from wired over to wifi connection?
Per Mfg website the NS-BRDVD does not have any network connections so you cannot use it on a wired or wireless network. You can only cable it with an HDMI to the TV.
DNS address not connecting to insignia blue ray
I have a wireless router{frios verizon} and a vizio blueray dvd player. HHow can I watch netflix on a TV(wireless) in the other side of the house without hooking it up with wires?
1helpful
Insignia Wifi Blue Ray DVD player connects to internet but sometimes it quits and tells me internet is too slow. What can I do to solve this issue
Must have a higher speeds internet connections for the Wifi or have wire connect directly to the internet connection for a stronger signal down load data's far ahead of the data's being for the Blu Ray player in used.
The Insignia NS-WBRDVD blu ray player will not connect to the wi-fi network in my home after countless attempts and efforts.
This is a common problem. If you go to the Insignia web site and find the forums, you will see a 40 page list of wireless connection problems. The wireless section of this player is junk. Use the wired connection and save yourself a lot of aggravation.
Web key changed. How do I re enter correct wireless address?
Enter the Settings section of the player.
Open the Network settings.
You should see a "Disconnect" selection.
Once you disconnect your network, you should be able to create a new connection with a new key.
Hope this helps!
Cannot find quick set up guide for wireless internet connection.
Turn on the player.
Go to Settings.
Go to Network.
Follow the setup instructions.
If you are using the NS-BRDVD, there is no wireless radio in the unit.
If you are using the NS-WBRDVD, then these instructions should work for you.
Hope this helps.
Let me know if you have difficulties.
How do I find the ''Quick Set Up Guide'' for wireless internet connection on this website. I purchased an Insignia NS-WBRDVD and the instructions stated that I could get a guide at this website. When I try...
You need to enter your network ID, enter the passcode for wpa2 and it should connect. If you are using WEP, it won't work. If you change to WP2 all your wifi needs to change to WPA2.
You may have to select a manual code (on your Wireless Point) for WPA2 so you don't have to type in 64 characters.
You don't name the website so I cannot investigate.
I have a insignia ns-brdvd3.i like to connect to net-flix
Since you don't have the wireless version of the ND-BRDVD, you will need to purchase an eithernet cable to run from your router to the player (there's a network port on the back of the player).
Simple as that...one cable and you should be up and watching Netflix!
Hope this helps!
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
