Start button will not initiate on cycle. Get 3 beeps.
Our Whirlpool Duet dryer will apparently power on (power button) green, but when we
press "start" and hold it down, it sounds 3 quick beeps and will go no further. When we
press pause/cancel twice to clear the cycle, the first press of the pause button only serves to turn the dryer off. We have tried adjust the combinations to the "normal" settings, but the start button still gives off 3 beeps. In fact, it seems no matter what buttons we push,
we get 3 beeps. I have checked the external electrical connections and the fuze box.
All seems normal there.
Any suggestions?
To unlock the Control Locked feature: Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control Locked light is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If holding doesn't unlock the feature, it is likely a faulty interface. I am having the same problem with my Whirlpool dryer and it is the interface, but it seems that a lot of people are able to correct the issue just by pressing the End of Cycle button for 3 minutes.
Here is a link to parts, numbers, and prices from Sears:
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
won't start cycle 3 second pause/start button keeps flashing
