Periodically I am getting an F09 fault code in the middle of a wash cycle. I don't know the model number of the washer but It was the only duet machine available at the time I purchased the machine. The washer is 5 years old.
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
F05
I have the exact same problem. Already checked the filter. Repair man cam out and changed out the pump motor. Still the same problem. How do you check the pressure switch?
I had the same problem, "F09", coming up on the panel that would shut down the washer. The solution given by Jeff was "spot on". All I had to do was clean out the pump filter as he recommended. In the filter I found a paper clip, two small safety pins and a couple straight pins. The steel in these objects was rusting and started to clog the holes in the filter. All I had to do is "Scotch Bright" the iron oxide stains off the filter and the inside of the filter. The washer is working great now, (New baby in the house, so it's getting a workout).
FALUT CODES E01,F09, ON WHIRLPOOL DUET WASHER
service code f12 on washer I have pressed reset code as instructed but still not working
