If you are not using the original pedal it means that your pedal is wired backwards. You can try disassembling the pedal or the plug on the cord and reversing the wiring of the connections to see if that helps. Example if the shield of the cable is wired to the shaft of the plug, try disconnecting the wiring to the shaft and tip and wire the shield to tip etc.
