The Service Manual covering mixers with the control plate can be downloaded at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Things to consider:
The brushes have a chamfer on one edge and must be oriented so that the chamfer can pass a small stop in one corner of the brush sleeve.
Are all the wires to the control board connected correctly? The board is marked for the wires colors.
There are instructions in the manual for measuring the stator coils to find out if they are OK or not.
Checking out the armature is another whole thing and you can get information on-line about this (try searching "armature testing"). I really hope that you don't need to go this far.
SOURCE: kitchenaid mixer k45ss slow gear
If you look into the brush holder you will see a stopper at the botom ,(this is so when brushes are wore the spring is not driven into armature) .. the brushes have to be inserted so the groove is lined up , try that
SOURCE: I have a Kitchenaid Professional
hi
there is a ring clamp on top of the main worm follower gear on the drive shaft. you might not see it due to the grease.
you need to get one of those weird little pliers with points on them to spread the ring clamp to remove it. Then the gear is just friction fit on the shaft...it's pretty tight. I carefully used a screwdriver to slowly separate the main follower gear from the lower gear and it goes up the shaft....
after a bit you can wiggle the follower gear by hand and it will come up. Then you can see there is a pin holding the drive gear underneath it in place. The pin in my mixer was actually bent (must have been some tough dough).
then you reverse the process to put the gear back on -- except that the top follower gear has to go on the pin in the right orientation or the ring clamp won't fit.
buy your parts from mendingshed.com
hope it helps.
SOURCE: KitchenAid KSM5PSGR Stand Mixer - attachments not turning
Hi Gail. Kitchenaid no longer has a Parts List for your model. This means that they consider it obsolete. Do an Internet search for parts. You may get lucky. Good luck!
If this solution has assisted you, please rate it. ricardok45
SOURCE: took brushes out to check and cannot get
Look at the brush from the side.. The surface that rides on the armature is curved> One leg is longer than the other leg. The long leg is the trailing and the short is the leading edge. Looking at the cooper end of the motor you can tell which way the motor rotates by the traces the brushes make. The leading edge will be on the clean side and the trailing edge is the side that is smeared black.on tthe copper. The long leg of the curve on each brush goes on the smearch side of those copper bars the brush rides on. Both brushes. Looking in the hole of the brush holders you will see what I mean. When you put the brushes in, you must make sure they are up against the copper and the springs are holding them down evenly.. You can lift the brush carefully and let it go to make sure it is working freely. Now, see if you can put an attachment on and turn it by hand. I'm not sure you will be able to so don't bend anything or hurt yourself.. Put the brush caps back on, remove the attachment and plug the mixer in.. Attachments off, fingers clear, turn it on. Does it run? If not, tap the mixer on its side with your hand.. Make sure the switch is on high. Tap it several times if need be. This is to straighten up the brushes to where the springs want them. When the motor starts turning, slight taps help. Keep it going until it picks up speed and let run for five minutes to seat the brushes. Let me know if it still won't run. I'll be watching for a comment from you.
Testimonial: "thanks so much, next time if it works, i won't try to fix it!!!!!!!!! thanks very much"
SOURCE: k45ss kitchenaid stand mixer, i took out the brushes
jrichards - I hate it when that happens! It seems that power is not getting to the armature from the brushes so I would suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the armature. The concave contact face should be resting completely on the armature. If you've turned it 90 degrees too much, it wont' seat properly. I hope this helps... Howard, Burke, VA
