If it appears that water got inside the tablet, you need to dry it off and then carefully pry off the back of the tablet. They will come off, but it must be done slowly and carefully. Blot up any visual moisture. Place a fan to blow over it and let it dry for a few hours in a warm area.
If you are not comfortable removing the back, take it to a phone/electronics repair location for assistance.
Before you take it anywhere why not try this idea. I had an iphone that was dropped in the bath tub full of water. I tried to dry it with a hair dryer but it did not work. My oldest daughter told me to put it in a plastic bag of dry white rice and seal it closed. Let it stay in the bag for a few days to give the rice time to absorb the water that is in the phone. I did this and left it for four days and removed it from the rice and the phone started working right away. Its worth a try.
If the kindle won't turn on because it was recently dropped or water was spilled on it or something, you should consult your warranty. If this is due to no external event/damage you should call amazon and see whether or not there's an update in software or a bug of sorts. If it's on their behalf you'll get a replacement device. Good luck!
It sounds to me you have BIOS password problem. When powering the computer up, Widows I'm guesing,.It probably very quickly has an option to F@ and F12. Press F8 to put the computer to safe mode. From there run a regerestry fix.
I hope that works for you. P.S. That is free too!!!!!
I did the same some two years ago, with the R100 on. I switched everything off, dismounted the computer body (not the screen)up to the last screw, and dried that sweet coffee from everywhere where I found it. Mostly this was the keyboard and mouse. The motherboard is luckily protected by some plastic sheet.
Regarding the keyboard, after disconnecting it from the motherboard, I washed it completely under flowing water and then let it dry for several days. In the meantime, I used a USB one. Since then, I used the same keyboard for two years until now, when it died, apparently rather from some motherboard-related reason than water. So I think - you may get a new keyboard, but if youre lucky, you may as well revive this old one.
Any hope you may have left other than an expensive repair, is to remove the battery and leave the unit in an airing cupboard for a week and pray. Then replace the battery and try again. No change - then nothing lost. I know it's basic, and best done as soon as the damage was done, but has worked for me in similar circumstances. Don't be tempted to use a warm oven.
