Linksys Wireless-G WRT54GS Router (e125894) Logo
Posted on Jun 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I recently got a Mac desktop and my Linksys router disk will not open up. Do I need a router that is made for Macs or is there a way to configure the Linksys?
Anonymous
Level 3:
  • Master 428 Answers
  • Posted on Jun 23, 2010
Anonymous
Master
Level 3:
Answers
428
Questions
Helped
189493
Points
1253
Hi, You are correct. The CD is not compatible with Mac. What you have to do is Configuring the Router Manually using the Web Based Configuration panel.
How to:
  1. Open your Web Browser
  2. Type http://192.168.1.1 in the Address Bar and hit Enter
  3. If you have changed the address somehow you have to enter that (Router's IP - Default Gateway)
  4. Here is a small guide to Fine your routers IP address in case of that you are unable to access
  5. Enter the user name (default user name is blank- means no user name. Just leave it blank), Default password is admin.
  6. Now you can configure the Router using the Menus.
  7. Make sure that you have Saved your settings before Exit the Web Based Setup.
  8. Make sure that you have changed the Default Password.
  • If you can’t access the router’s web-based setup page, please check the following: cable connections, router’s LEDs, IP address, and connectivity.
  • Connecting Devices Together
  • Ensure that you have an Active Internet Connection and connect the modem to the router’s Internet port and the Mac to any of the four Ethernet ports.
  • Checking the Router’s LEDs
  • After connecting your modem and Mac to the router, check the lights on the front panel of the router.
  • Checking the Router’s IP Address
  • To find a Linksys router’s Local IP address, you have to check the IP settings of the Mac
  • Checking the Mac’s Connectivity with the Router
  • Ensure that the Mac is properly connected to the router.
You can download the Manuals from here to learn how to do Advanced, Customized Configurations.
Note: Please select the appropriate Hardware Version.
Thanks for contacting Fixya! Feel free to ask any questions if you face trouble with the setup. Please rate the answer as well!
Why won't disk insert into iMac
Probably not configured correctly. Have you tried this same disk in other Macs?
Linksys Wireless Router re-set
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
CM100 Cable Modem
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router and protect your wireless network from unauthorized access.
http://192.168.1.1
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
I had this router connected to my desktop so my grand daughter could use her labtop,my desktop crashed and I had to replace my hard drive and my memory and lost all information on the router and I lost the...
You actually don't need a setup disk for setting up a router. Try the following steps.
  1. Reset your router to default configurations by holding the reset button for 15 seconds.
  2. Make sure your desktop is set to "obtain an ip address automatically."
  3. Connect an ethernet cable between your router and desktop.
This should get you connected to the router. If you want to make any configuration changes, perform the following steps.
  1. Open up a web browser.
  2. Type in the address bar 192.168.1.1 (Default IP address of Linksys routers)
    This will connect you to the router.
  3. It will prompt you to login. The default username is blank (no text at all) and the password is admin.
I set up my WRT120N router. My desktop is connected to the internet with the provided ethernet cord, but my friend's macbook cannot connect wirelessly. He keeps getting a "timeout" message. ...
You Linksys wireless settings ie. SSID and encryption etc these settings are needed to configure the wireless card in the MAC so it can connect to the Linksys.
2helpful
Hi..I have a Linksys Wireless Router WRT160Nv3. Is it possible to recover the admin password of this router. Don't want to reset the Wireless Router to make it a fresh setup because the router have very...
Is the computer that you used to configure the router still working? if yes, then on that computer there is a "linksys.txt" file on the desktop. All the router info will be there. Other than that, you need to reset the router.
Settings on Linksys router for the DCS 5220 to view remotely and settings on Securicam
Configuring your Linksys router for remote desktop is a task that's needed before you can access your computer from outside the network. If you plan to connect to your remote desktop machine from the Internet, you need to configure the router to allow traffic to the PC. Linksys is a common router used on home networks for wireless and LAN configurations. Configuring your router to allow port forwarding to a remote desktop only takes a few steps through the graphical user interface.
  1. tep 1 Open your browser window and type the IP address of the router in your address bar. This opens a window for the username and password needed for access to configure the router.
  2. Step 2 Click the "Applications and Gaming" tab on the opening screen. This opens a window with a list of ports of which you can open for access on your network.
  3. Step 3 Type "Remote Desktop" in the application textbox.
  4. Step 4 Enter "3389" in the "Start" and "Stop" port ranges. This port number is specific to the remote desktop application.
  5. Step 5 Leave the value of "Both" in the protocol listbox.
  6. Step 6 Type the IP address of the internal machine on your network. The IP address is the machine running remote desktop. When traffic from the Internet reaches the router, it forwards the request to this IP address.
  7. Step 7 Check the "Enabled" checkbox and click "Save Settings."
  8. Step 8 Close the browser window.
Cant connect wireless laptop
Hey folks, try the following things. Hope it helps !
1. Connect the cable from your modem into the Internet port of the Linksys router.
2. Reset the router with the reset button for 30 seconds when the router is ON.
3. Turn the router and the modem OFF.
4. Turn the Modem On first, wait for 10 seconds and than the router.
5. Your Internet should work from the computers connectedto the router.
6. If not open the setup page of the router by typing 192.168.1.1 in and browser, the default password is admin.
7. In the setup page, below setup tab, the 3rd subtab is MAC Address Clone, Click on that and click Enable and click Clone the MAC Address.
8. Repeat Steps 3 and 4.
For more info on linksys devices, you can try these links :
http://linksysfirmwares.googlepages.com/configurations
http://linksysfirmwares.googlepages.com/wirelesssecurity
If you want to configure the Wireless on the router :
Click on the Wireless TAB, change the name [SSID].
  • Connect the computer to the router.
  • Open the setup page. Default password is admin.
  • Change the channel to 11-2.462 GHz.
  • If you want to enable wireless security, go for WEP 64 bits.
Installation linksys wireless-g router
In order for you to setup the WRt54G to work with your Ibook you nee d to manually configure it since the setup CD for the WRt54G wont run on your MAC computer, In manually configuring the router you need to access the setup page of it and there you can set it up, I will advice you to contact Linksys tech support so one of their tech can walk you through with the process the number 800-3267114 they are open 24/7...
Hope that helps...........
How to install this Linksys wireless-G WRT54GS with a Mac?
you can configure that router without using the bundle CD. the default ip address for that router is 192.168.1.1. open internet explorer then type the ip address which is 192.168.1.1. then the default username is "admin" (without " ") then password is "admin" also. then you are now on the linksys webpage and you can configure there. it is much easier to use rather than using the bundle CD.
hope this can help you!
good luck
charles
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
