SkyScan 86742 Digital Atomic Wall Clock Logo
Posted on Jun 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you set time zone model 3229-1
How do you set time zone model 38
229-1
Sean Goodman
Level 1:
  • Contributor 4 Answers
  • Posted on Nov 07, 2010
Sean Goodman
Contributor
Level 1:
Answers
Questions
0
Helped
2295
Points
7
Starting in time mode:
1. Press "MODE" (brings up alarm time) 2. Press "SET" (toggles between the four zones)
P - Pacific
M - Mountain
C - Central
E - Eastern
3. Once the desired time zone is set, press "MODE" to return to the clock.
Anonymous
Level 2:
Scholar:
  • Expert 154 Answers
  • Posted on Jun 22, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
154
Questions
0
Helped
68762
Points
461
Press the Mode button to display the alarm time then press the Adjust button till you get tot the corret time zone, press Mode again once have found the coreect timezone.
I have a Sharp Atomic clock , model SPC373 and the time is incorrect. Everything else is ok, how do I correct the time?
To correct the time on your Sharp Atomic clock, you will need to reset the time zone. To do this, press and hold the "Time Zone" button for 3 seconds until the time zone flashes. Then, press the "Hour" and "Minute" buttons to adjust the time zone to the correct time zone. Once the time zone is set, press the "Time Zone" button again to save the settings. The clock should now be displaying the correct time.
Aug 13, 2022 • Home
1helpful
How do I change the time zone for model 31981B?
How To Set Your Time Zone
Time Zones around the world are identified by how many hours they are off-set from Greenwich Mean Time. US time zones are 5 to 9 hours behind Greenwich Mean Time and are identified as:
Eastern -5 Central -6 Mountain -7 Pacific -8 Alaska -9
Your SkyScan model 31981 is pre-set to Pacific Time. To set your clock to your time press and hold the mode button for 2 seconds. The off-set hours will appear and blink in the clock window. Press the up or down button to designate your time zone. Press the alarm button to exit time zone setting mode.
http://skyscanatomicclocks.com/manuals/31981.pdf
2helpful
On a Nexxtech model 6312026 how do i set the correct time zone?
The manual is available at: http://downloads.thesource.ca/631/6312026/Manuals/manual.pdf
To set the time zone press the MODE button once so that the day of week is displayed to the right of the time. Select the time zone by pressing and holding the UP button for 3 seconds.
I have an Eddie Bauer Wireless Thermo Clock model 0465.\r\nWe replaced the battery and now it is on the wrong time zone. How do I change it>?
Re: Eddie Bauer Wireless Thermo Clock - Model 0465
TIME ZONE SETTING
The default time zone is PACIFIC (P). lf your location is not in the Pacific zone, set the time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln alarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern.
4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit automatically 30 seconds later without pressing any key.
This sequence fixes my thermo clock. Follow step-by-step ......
Sent via Mobile GMail Services
06.20.2021 KJ Bleus Parsons
3helpful
How do I change the time on my TIMEX T307S clock?
Hello
To adjust time follow this.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
4helpful
We have an atomic clock with calendar and temptature on it. We changed the battery and it is now on Eastern time zone, not Pacific time zone. How do we set it? It is La Crosse Technology Radio Model #...
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
3helpful
How do you set the alarm for pacific standard time on the emerson
Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
Skyscan model 87800
Press set button repeatedly -you get timezone mode
and change your wished time zone (for help go through time zone codeing list) and select your zone then press set button to normal mode and adjust the current time.
1helpful
2answers
Correct Time Zone
Using the Emerson CKD5809C manual (also with SmartSet(tm) ), try Zone 4. TIME ZONE button: "04".
Zone 1: Atlantic Time
Zone 2: Easter Time (Default)
Zone 3: Central Time
Zone 4: Mountain Time
Zone 5: Pacific Time
Zone 6: Yukon Time
Zone 7: Hawaiian Time
Reference:
http://www.emersonelectronics.ca/emerson/en/category/list/694
or
http://www.emersonelectronics.ca/emerson/en/product/details/2361
As for disabling the Daylight Saving Time (DST) time change I have some guesses to try (not having one of these radios in my hand) or just skip to #4 below.
1. Manually setting the time and see if this disables the DST change.
2. Is there a Zone setting other than above? Like maybe a Zone 0? And then manually set the time.
3. Look at http://www.fixya.com/support/t236208-daylight_savings_time_adjustment for my solution there and try adjusting the DST Start to the same as DST End or DST Start and End with a month of 0 (if that is possible).
4. Or for the really desperate, change the Zone to 5 during DST and back to 4 during standard time (no worst off than with no DST auto setting.) (After I wrote this, I found an Emerson reference to no DST areas, Saskatchewan in this case, in the CKS1850C manual http://www.emersonelectronics.ca/emerson/en/product/details/2383, pg 9, and this is their solution.)
Top SkyScan Home Experts
john h
Paul Carew
Are you a SkyScan Home Expert? Answer questions, earn points and help others
