Hi. i have the first tomtom one GPS navigator. the "leg" in the back that connects the devide to the windshield broke off and i need to replace it (the whole thing has an insert to connect to the device and i would like a new insert. where can i get one?
If it doesn't continue to show the license and owner screen, it means that the TomTom (navigation) software is not running properly. Often it means that the software is corrupt, and it has to be repaired or replaced.
If you are able to connect the TomTom device to a computer (using the USB port), select the TomTom disk, right click and select Properties, and run the TOOLs to check and repair the (TomTom) disk. After completing the repair, disconnect it (from the computer), restart the TomTom - turn it off and turn it back on, and see if you get it going normally. If not, you'll need to restore your navigation software from your backup and see if it works. Or you can download the navigation software from the TomTom website and copy it onto your GPS device.
If your navigation device shows only the start-up image or you see a
flashing cross after you switch it on, it means that the TomTom
application is not installed or cannot be found.
Well a new mount suction cup will need to be purchased. you can grab one at radioshack.com you alsmo might want to wet the plunger then try to stick it. Or clean of that dirty windshield and try again.
2 solutions
1. clean the windshield and apply a little water to the back of it.
2. Buy a new suction cup.
thats all I hope you to stop by and rate it thanks.
Connect your device with TomTom Home and access the memory (like if it was an external disk)
Create the following 2 files without ant extension in the root:
cleanflash
runclean
It will reset your devide to the original settings.
When starting it will ask you which language you want to use.
Hi. You need just "zip" codes simply connect tom tom to computer then find zip folder on yahoo or use this link http://www.tomtomforums.com/attractions/1563-zip-code.html first post , unzip the folder and copy on tom tom the problem could happen still the best way will be to get new software using for example tomtom home aplication but please copy maps on computer for example western_and_central_europe or just uk that will be only one folder also please make a copy of voices folder at the end just please format tomtom device reboot connect to tomtom home get latest navcore should tell automatically that you need navcore and download it install tomtom home will do this automatically and copy back maps and folder voices with zip codes folder as well. sorry for my bad english
I have owned an off brand GPS unit for about 3 years and wanted to upgrade to a TomTom GPS unit. I have recently purchased a TomTom ONE XL. The TomTom will not stay mounted to my windshield. I have cleaned the suction cup and the windshield and nothing has helped. After the unit has been mounting for about 30~45 minutes it will fall off the windshield. I am afraid if this continues my TomTom GPS unit will be damaged. I have never had this problem before and as I mentioned earlier, I have owned a GPS unit for about 3 years. I noticed that the TomTom mount is very cheap built. Can you send me a better mount for my TomTom One XL? I am very disappointed in the unit so far and I only owned it for about 2 weeks.
