My tyros2 plays an additional note (F#3) when I play two particular notes simultaneously ( C3 and E3). The F#3 note is high pitched and distinct and really irritating at regular intervals. Please advise. Thanks
I have found my schematics. The F3# and the C3 and E3 all have common interconnects in the key scanning matrix.
The following diodes on the key contact board need to be checked:
D49, D50, D57, D58, D61, D62.
These diodes block the hazard paths of the scanning when more than one note is held down.
You MAY find some contamination is shorting one of the diodes rather than the diode being bad itself.
The scanning is of a conductive rubber key contacts so is high impedance as the contacts don't go near zero ohms when pressed. Leakage in the diodes can cause the problem. I would first visually look for shorts on the board affecting the conductors tied to these diodes.
Clean the board and contacts with 99% isoprophyl alcohol and Qtips.
You will have to remove the sets of keys that are held with several screws. I believe they are modular and the keys are in groups of white and two black groups per octave. Under the keys is a silicone strip of domes with conductive pills, two per note that are pressed onto the board. The two contacts close at different times so they can measure key velocity.
The key contact circuit board is in two parts, a high and a low section. To remove, you will have to remove all keys and the silicone strip over the section of board of interest.
