Good day, I have a 15 year old Top Loader Stainlees Steel drum Speedqueen washing machine. A brilliant machine.On the weekend we relocated to another house.In turn we moved the machine.Now after the first wash, we have a small bit of liquid coming out from underneath the machine. Is it a pipe that might have come loose in the move.Help!
SOURCE: Belt
We'll assume no problems with the belt installation - the tensioned idler pulley is pressing against the belt etc.
You didn't say whether it drained out OK or specify what model but it sounds like the brake is stuck or there's something caught in the basket. Try turning the main drive pulley (the one in the middle) Even with it full of water it should turn freely. Take the tub top off and check for foriegn obects stuck between the basket and outer tub. A wire coat hanger works well fro this.
SOURCE: SpeedQueen washer trouble
You could have a couple problems, it could be the timer, motor or Transmission.
Start by removing unplugging the washer,
Now remove the front panel, two 5/16" screws at the bottom of the front panel. the front panel will either drop off or you have to turn it up to remove it
In the front on the bottom is the motor, on the bottom of the motor is the belt. This belt drives the pulley on the bottom of the transmission. It should turn both directions. in one direction the transmission will ramp up and unlock the brakes letting the unit spin. The other direction the transmission will cause the agitator to turn back and forth. you may need two people one to watcht the agitator and one to turn the belt, Now if the transmission does not turn at all you have what is known as a locked transmission. This is a major expense. Look for a new machine.
If the machine does actually agitate and spin when you move the pulley it could be as simple as a motor or timer. Please let me know what you find and we can go further.
T
SOURCE: Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
SOURCE: Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
SOURCE: 28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
3 Remove the lint trap from the lint compartment on the top of the dryer.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use .
