Question about Sony PlayStation 2 (PS2) Console
Took off cover to clean attached to covers underside white lead didn't see where it was attached? if you could give me a hint that would be great
    Scholar:
  • 154 Answers
The white ribbon cable attaches tot he circuitboard for the controller sockets at the front of the console.
Posted on Jun 23, 2010
6ya staff
SOURCE:
I took a self portrait with my fuji instax mini 7s but when the film came out, it was just white. I waited a few more minutes but it still didn't have the picture i took. What's wrong?
It comes out white cause you just took the picture. It takes a few moments to "develop" the picture that will be on the card. If you don't see nothing maybe the lens was covered...but it most likely be black as in something was on the card and developed.
how to load film here:
http://www.youtube.com/watch?v=Vq8JguPxq3w
see more here:
http://www.youtube.com/watch?annotation_id=annotation_90634&feature=iv&src_vid=Vq8JguPxq3w&v=-00VbGm3uzs
Sep 15, 2012 | Fujifilm Instax MINI 7s Instant Film...
Tip
Hot Tub - Spring cleaning and Maintenance
Spring is a great time to change the water in your hot tub and clean or replace your hot tub filters. Drain and give your hot tub a good thorough cleaning to rid yourself of the winter season. Make sure that you clean your hot tub cover at the same time both the top and the underside. This will help the hot tub cover to last longer and perform better. Hot Tub Spring Cleaning Tips
on Mar 27, 2015 | Pool & Spa
Rca drc8335 will not completely start up. HELLO on display seems to get stuck and system will do nothing.
If you know how to solder then you can fix this one. Make sure unit is unplugged and then remove cover. After noting their locations, unplug the white connectors and the two AC leads from the Power Supply board. Remove the (5) screws holding the board and remove it. Find the capacitor marked C226 and make note of it's polarity. It is a 16V - 470uf Electrolytic. Carefully remove it. For under $2 at radio shack you can buy a replacement. It will be a 35V - 470uf and may have axial leads (leads out of each end). Note that the arrow points to the negative lead. Bend this down the side of the capacitor and straighten the positive lead and feed the two leads through their proper holes. Solder the leads on the underside, snip off the extra lead length. Re-install the power supply board and re-connect the plugs and the two AC leads White to pin marked White and Black to pin marked Black.
Note that the two short mounting screws go into the tabs from the back of the case. Check your connections one more time.... Replace the cover plug it in and Ta Da.
Dec 23, 2010 | RCA DRC8335
Need to remove top of scanner microtek scan wizard 5 to clean underside of glass
Follow these steps to clean the scanner :
Open up your scanner's lid. It does not matter if the scanner is on or off for this basic, regular cleaning.
Wipe down the glass surface with a dry, lint-free microfiber cloth. This will remove any dust or other fine particles that have accumulated on the scanner. You should remove excess dust every day or two.
Scan a blank sheet of white paper into your computer and look for visible discoloration. A white sheet will provide a clean, blank slate to view the scanner's overall quality. If you notice any irregularities on the white sheet, you need to do more thorough, semi-regular cleaning.
Semi-Regular Cleaning
Turn off the scanner and open up the lid.
Spray a small amount of "mild glass cleaner" on a soft, clean cloth as recommended by Scanner-Magic.com.
Wipe the scanner's glass to thoroughly clean the area. You should perform this semi-regular cleaning at least every two weeks or sooner if a white sheet of paper indicates discoloration.
Keep the scanner's lid open for a few minutes until all excess glass cleaner has dried.
Nov 26, 2010 | Microtek ScanMaker 5800 Flatbed Scanner
Difficulty locating my Benz R350 Batteries
In the 2006, the battery is under the front passenger seat.
To get to it is complicated -- from manual:
Move seat as far back as possible. Seat rails have covers on them - slide them forward....the left one will only slide forward, cannot be removed. Between the two seat rails you will see two little battery cover mounting nuts. Use 6 mm T-handle hex key to remove the nuts. Move seat as far forward as possible and twist rear rail covers to left and right and then pull toward rear of car. Pull back/fold floor carpet under seat from front to back (carpet is perforated so you may have to really yank the first time). There are two more battery cover mounting nuts between rear seat rails. There is a battery cover with an air vent pull it slightly to right and then lift out. There is a vent hose attached to battery on left side -- pull it out. Unfasten & remove attachment nuts on left side (low). Remove the battery attachment once those nuts are off. Push battery to the left. Disconnect battery negative lead (right) (do not let it touch pos. lead on left). Remove cover from pos (red/left) terminal and disconnect lead.
Feb 15, 2010 | 2007 Mercedes-Benz R350
White wireless cord??
On the card itself should there be 2 x connection points,the black one is ,already connected and the other should be right next to it,within an inch(25mm) ,you can remove the black lead to see clearer what the connection point looks like,they are push on connections,and will be 2x tiny brass or gold coloured female connectors,side by side,
apart from that ,
the length of the leads will not stretch too far from their place of connection,
Both power the wireless card,
One is positive(+) and the other is negetive(-)
Hope this helps,need a photo to explain???
GOOGLE it,
try typing in the card number of the cards sticker and select image search,
Thanks and have a great night,
Misterdj
Jan 14, 2009 | ASUS A6U Notebook
Shadows appear when printing out
Heating unit (fuser) 's teflon roll is dirty causing ghosting. Either replace with new heating unit (it is on front top near paper output) or clean it.
It can be cleaned carefully with electonic cleaning spray (non grease) WITHOUT using any force (be patient) wiping with cloth and spraying again and again utill it is clean. Then spray silocone spray to cloth and wipe teflon with that.
Open unit: Remove mains and usb/network leads. Remove paper holder (printed papers) from top back. Under that you'll see small arrows on both sides. Push screwdriver to hole and release locks. After that you can raise dark lid from top. Under that on white lid there is 4 screws, open them. Open all back cover scews and take the cover out lifting from bottom edge. Open 1 screw from right cover (where network socket is. Lift white top cover a little bit and then you can open right side cover (from back to forward). Under cover there is flat cable coming from display unit. Open it and then you can remove top white lid. Push the rest of dark paper holder backwards (on top) and it opens and you'll see the power supply under that. When looking from back there is 1 screw at right holding black plastic roller plate. Open the screw and bend the plate to left (looking from back) Now you can see 50% of brown teflon roll that is around the heater lamp. Clean it with spray and cloth pushing CAREFULLY from bottom to top.
Do NOT push teflon horizontaly as there is nothing on back of teflon and it may broke. Underside there is a metal plate under teflon and you can use LITTLE force for wiping. You can rotate teflon pushing white gear at top (from top to bottom, it turns only this direction). When totally clean, wipe with cloth sprayed with silicone spray.
I do not know how long this helps (just did it by myself) but the printing result is perfect again with same color casettes than before.
Sep 13, 2007 | HP Color LaserJet 2600n Printer
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
