Question about Becker Silverstone 7860 6-Disc CD Changer
I have a Becker Europa 2000 radio Model BE1100 Serial number A 0704182 when i turn it on four spaces appear on the screen and i cant write or do anything on it, it seems that i wrote the code wrong for three times so what should i do??
  • Becker Master
  • 5,013 Answers
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself
This is usually an hour or two
Posted on Jun 23, 2010
    New Friend:
Ihave becker europa2000 be1100 sn/ c4621523 ineed the cod thank you
Posted on Oct 02, 2013
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
HOW DO I FIND THE CODE FOR MY BE1100 BECKER EUROPA 2000
Posted on May 31, 2013
  • marwan Oct 02, 2013
    ihave becker europa2000 be1100 sn/ c4621523 ineed the cod thank you
6ya staff
SOURCE:
I have trouble in putting the code in as the digits are not available on screen Model of radio is Becker BE6802 and serial number 51070291 - my screen only has buttons from 1 - 6 but my code is 0498
Have you tried turning the volume knob to input the digits? Then using next button for the next digit placement.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Aug 25, 2017 | Becker Car Audio & Video
Radio code
  • Turn off radio.
  • Hold down the TP button for at least 10 seconds.
  • Turn the radio on. "Becker 1" will be displayed.
  • Rotate the right knob slowly, as it will display the Becker model number.
  • Rotate again and radio serial number will display on radio display.
  • Press tone, then 8 and 0 simultaneously "Becker" appears.
  • Press station up arrow on right, "PR-VERS" appears.
  • Press one of the numbered buttons below display, directly below the LCD arrowheads.
  • The model number will appear.
  • Press station up arrow on right until, "SERIAL N" appears.
  • Press the numbered button again.
  • The serial number will appear.
  • Traffic Pro:
    • Select the Service Menu.
    • Press NAV and multifunction key 10 simultaneously in radio mode.
    • Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
    • Rotate knob until the "serial"No is displayed.
      To quit the menu, press END.
    If you are unable to find your radio serial number by the procedures above, you can find the radio serial number located on radio chassis.
Apr 10, 2016 | 1998 Porsche Boxster
How to unock becker radio code lemans 30
The radio SERIALNUMBER will be required for calculating a code On some radios, pressing Buttons 6 and 1 or 6 and 2 (together) maydisplay a Serial Number If not , then removethe radio from the dashboard. Then post all the letters+numbers on any labels,barcodes or stamped inthe metal casing. This information canthen be used to see if a code can be calculated
May 08, 2011 | Infinity Reference 1211a Car Audio...
Need master code for radio in a 2000 ml320
Regretfully due to reasons of theft or piracy we do not pass the radio codes here at FixYa. If you contact your local Mercedes-Benz dealer they will give you the 5 digit code. (You must have your registration and know the complete serial number of the radio)
Kelly
May 05, 2010 | 2007 Mercedes-Benz ML320 CDI
I need the mercedes benz 1999 clk 430 radio code
AR82.60-P-7502-01A Coding Radio
(MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
  1. If the radio is disconnected from the power supply, it is not operational when re-connected. After switching on the ignition and the radio, the readout CODE appears in the display.
  2. The code number for the radio is advised to you on the enclosed CODE CARD.
  3. To enter the first digit of the code number, you have to continue pressing station button 1 until the correct digit appears in the display. Adopt the same procedure for the second, third and fourth digits.
  4. Once you have entered the correct code number with the station buttons 1, 2, 3, 4 and confirmed the entry with the SEEK button (press down), the readout CODE disappears. The radio can now be operated.
  5. If you enter a wrong code three times, you must wait 15 minutes before making a new entry. In addition, if 9 incorrect entries are made, the radio will then not operate for 24 hours. During this time the radio and the ignition (terminal 15) must remain switched on.
AR82.60-P-7502-01B Coding Radio
(MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
  1. If the radio is disconnected from the power supply, it cannot be operated by simply reconnecting. After switching on the ignition and the radio the word "CODE" appears in the display on the radio.
  2. The code number for the radio is given on the enclosed CODE CARD.
  3. Enter the code number with the station button, e.g. number 1, station button 1. After entering the first number the word "CODE" disappears and the number entered appears followed by 4 dashes. The next character to be entered flashes. After entering all five numbers, the first character starts flashing again. In this state the code number can be written over as frequently as desired. A correction can be made only by entering the complete code number again.
  4. Confirm code number: Press TUNE, AUTO/SEEK or SC button. The radio automatically switches on and indicates the radio station or frequency stored with station button 1.
  5. If an incorrect code number is entered and confirmed, the word "CODE" appears again on the display. If an incorrect code is entered three times the word "WAIT" appears on the display and the radio locks up for approx. 10 min. If the code is entered incorrectly three times again the radio locks up again for 10 min. Three more incorrect entries (a total of 9 incorrect attempts) increase the lock-up time to 60 min. Another three incorrect entries lock up the radio for another 60 min. The waiting time runs only when the radio is switched on.
Dec 17, 2009 | 1999 Mercedes-Benz E-Class
WAIT status on Becker radio - blockage
Hi try code 2183, it should reset the radio/cd
Jun 15, 2009 | 2000 Porsche Boxster
Security code for Becker car radio
lost radio code of MB Becker truckline CD65 BE 7045 serial no 68015713
Jul 29, 2008 | Car Audio & Video
Becker Silverstone 7860 6-Disc CD Changer Logo
1,270 people viewed this question
Top Becker Car Audio & Video Experts
xxxxxx xxx
Gil Shultz
Colin Stickland
Colin Stickland
Are you a Becker Car Audio and Video Expert? Answer questions, earn points and help others
