To arm the GE Simon 3 without the entry delay, press "Doors/Windows" button twice. The panel should say "Doors and windows on. No entry delay." To turn off the beeps for the exit delay, enter your master code while the system is disarmed, open panel cover by pushing down on the button on the very top of the panel. Then use the buttons with red numbers under them to enter your master code. Then press "Delete" "Option" "Done" "Done" then close the keypad cover. The panel will no longer make the beeping sounds.
TIME OF DAY MODE 1. Press C to toggle between Time 1 and Time 2. 2. Hold C for two seconds to set Time 1 or 2 as default. 3. Press D to turn on/off key tone. Time 1 > To set Time, press A until hour flashes. Press B to select the setting item. Use C and D buttons to adjust the values up or down. Press A to exit set mode. Time 2 > To set Time, press A until hour flashes. Press B to select the setting item. Use C and D buttons to adjust the values up or down. Press A to exit set mode. > The range difference between Time 1 and Time 2 is 23 hours. CHRONO MODE 1. Press C to start and stop chronograph. 2. Press D to Split/Reset the chronograph. 3. Press A to recall the memory if Chronograph is stopped. 4. Press A again to view the next lap. 5. Press C or D to exit Recall mode and go back to Chronograph mode. 6. There are a total of 10 lap memories. TIMER MODE 1. There are 3 different modes of timer: Count Down-Stop, Count DownRepeat, Count Down-and Up. 2. Press C to start/stop the timer counting. 3. Press D to reset the counter to the preset value if timer is stopped. 4. Press and hold A for 2 seconds to enter Timer Setting Mode. 35 Timer Setting Mode
5. Press B to cycle around the setting item: timer-type, hour, minute, second and to back timer-type again. 6. Press C and D to increase/decrease the setting value. 7. Press A to exit the setting mode. TIMER ALARM Timer alarm will beep 2 times a second for 30 seconds. ALARM MODE 1. Press C to select the alarm. 2. Press D to enable/disable the alarm. 3. Press B to change to Time mode again. ALARM SETTING MODE 1. Press and hold A for 2 seconds to enter the alarm settings mode. 2. Press C and D to increase or decrease the settings value. 3. Press A to exit the settings mode.
If it is wireless, then one or more of the switches need a new battery. I suggest replace them all and mark the date inside the box. I assume that there is no yellow triangle showing on the alarm panel. Triangle is for no phone connection.
Clear the alarm clock or take out the battery at night unplug it then if it beeps I would call that TV show that does the ghost thing I would be worried if that happened. Just kidding of course see if the alarm is on or if you have an alarm. Other when the battery is still plugged in and the power cord is still hooked up it could be the low batter or charged indicator letting you know it is charged. If it is the same time each night then it is the alarm clock that was set somehow maybe someone has a better solution. Check it out though. Interesting but frustrating I bet. John
you may find a manual from the manufacture. hold the mode button down 3-5 sec's. the hr should blink ,use the opposite side buttons to change the number, then press mode again mins blink change, do this and set hr,min,sec, am or pm? then date month,day yr. press final time and time should be shown with no blinking. you can also hold in all buttons and let beep 5 times it resets to zero defalt settings
Resetting Your Installer Code 1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process. Resetting Your Master Code 2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
you need to reset alarm/immobiliser.lock car with remote, hold button down for 30 secs,then press/hold down unlock button,should reset.another way is with key in ignition/turned on, press alarm button down and hold for 30 secs.this resets immobiliser.toyota
systems vary..depending on market.
If your Decade watch is like mine it has 4 push buttons (10, 2, 4 and 8
"o'clock" positions respectively; and one pull and turn stem (at 3
o'clock position) -
For the purpose of setting the watch and functions mentally label the push buttons as follows:
10 o'clock position "A"
8 o'clock position "B"
2 o'clock position "C"
4 o'clock position "D"
NORMAL TIME SETTING
1) In normal time readout press B (3x) to get to normal time setting
mode: "SEC" will start flashing, press C for synchronization
2) Press D once: "MIN" will be flashing, press C to advance
3) Press D once: "HOUR" will be flashing, press C to advance ("A" is for am, "P" is for pm, "H" is for 24 Hour format)
4) Press D once: "DATE" should be flashing, press C to advance
5) Press D once: "MONTH" should be flashing, press C to advance
6) Press D once: "DAY OF WEEK" should be flashing, press C to advance
7) Press B once: Setting is completed, return to normal time readout ALARM TIMES SETTING 1) In normal time readout press B (2x): Alarm time "HOUR" should be flashing, press C to advance 2) Press D once: Alarm time "MIN" should be flashing, press C to advance 3) Press B once: Setting is completed, return to normal time readout
ALARM FUNCTION 1) In normal time readout press C and D simultaneously: Alarm signal should appear 2) In normal time readout disarm alarm by pressing C and D simultaneously: alarm signal should disappear
Note: Alarm (when activated) will stop itself after 1 minute; or can be silenced by pressing D or press C to snooze for 5 minutes (operates for 1 hour) CHIME 1) In normal time readout press D and B simultaneously: Chime signal should appear 2) In normal time readout disarm chime by pressing C and D simultaneously: alarm signal should disappear
CHRONOGRAPH (STOP WATCH FUNCTION) 1) In normal time readout press B once to get into "CHRONO"
mode: press C for to start counting event - While in Chrono mode there are two options a) During a counting event: press C to stop counting, press D to clear and reset stopwatch to 0:00 b) During a counting event: press D to see a "split" time (IE first leg of a relay time is shown while the counting event continues, press D again to return to running counting event; press C at end of event, press D to reset stopwatch to 0:00 2) press B to return to normal time mode
