Life Fitness 9000 Next Generation Treadmill  Logo
Posted on Jun 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My treadmill says waxing needs refill maintainance required
  • Cece Cole
    Cece Cole Sep 19, 2018
    can you tell me where can I buy the waxer for the life fitness 9000hr
Joe Maestro
Level 2:
Sergeant:
  • Expert 181 Answers
  • Posted on Feb 13, 2013
 Joe Maestro
Expert
Level 2:
Sergeant:
Answers
181
Questions
0
Helped
64559
Points
563
1) Flip the treadmill on its side to expose the bottom 2) remove the two screws holding the rectangular metal wax cover 3) remove the wax cover 4) you should see a bag of wax, replace it with new 5) type in 5-1-2-5-Enter to reset the wax statistics
tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 • Exercise & Fitness
2helpful
3answers
Lubricating walking belt
Video about How to Wax a Treadmill Using Powder Wax
How to Wax Treadmill Using Powder Wax Video
Video of How to Lubricate a Treadmill using Liquid Lube
How to Lubricate Treadmill Using Liquid Lube Video
Precor c965i won't maintain speed the more weight on it
weel you must read the specification of your model, what is the maximun weight that is acceptable. However you must LUBE the deck belt with silicones or wax , read your owner manual for this, and execute inmediately.
God bless you
1helpful
How do i refill the wax on my life fitness 9100 treadmill?
open cover on left at rear of treadmill, disconnect pipe, fill with wax kit and then reconnect pipe, 2 screws to remove wax cover.
1helpful
I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
2helpful
I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
1helpful
Left side rollers are releasing excess oil.. getting oil shooting out onto carpet.
On that left side end cap has a liquid wax hose assembly with nozzle on/off switch, this is used to refill the wax bladder underneath the running deck for lubricating the running belt itself. their are 2 screws that hold the end cap you will see the nozzle make sure its turned off make sure hose connections are snug. If any cracks in hose replace accordingly.
1helpful
Refilled with wax how to reset display
you have to enter maintenance mode, press (CLEAR) and then press the key (PAUSE) there will appear a message that is doing a checkup, then using the keys you move up to find "Maintenance" and press enter Ahi provided with keys look for the option "WAX REFILL" press "ENTER" and ready and be 100% if you have any additional questions here's my e [email protected]
9helpful
2answers
Treadmill wont run its saying waxer empty and notify maintainence
Does this treadmill have a wax system ? If it does it will have side access panels on the side just above the rear leveler. The picture that shows here does not but need to be sure it does not really need wax.
If it does not have a waxer- enter maintenance settings on display console,I do not have one in front of me but I believe you hold pause button down and press clear twice. This should bring up maintenance settings.
Scroll using up down arrow untill you see replace wax bag or something to that effect. select [enter ] to save. press clear clear to restart.
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
