Temperature Alarm My son took something out of the freezer around 2am and did not notice that the door did not shut completely, I notice around 10am that food in the freezer door was not frozen and water on floor near the door. The Temperature Alarm light has been on since then. What needs to be done?
Although you could just close the door and it should right itself,could it be the right time for a total defrost and clean.all the drains/vents.....auto defrost only does the inside of the unit,
Possibly a problem with one of the components in the automatic defrost system in the freezer then.. this is the only reason why the alarm would keep sounding. Perhaps some of the moisture from the defrost has gotten in and damaged the electricals somehow. It might be worth it to store your freezer contents elsewhere and completely defrost the freezer and then heat the inside cabinet up with a hair dryer or something similar. This will dry out the cabinet and the electrical components. Once the freezer has warmed up let it stand for as long as possible with the doors open so that it reaches room temperature and then close the doors and switch back on. If this doesn't work you probably need a service engineer visit.
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
The alarm usually is telling you that the temperature inside the freezer is not low enough. Check the door seals with dollar bill. Shut the door on the bill and try to move it. Try all around the door. The bill should resist being pulled out. If you can't pull it out the door is too tight. If it comes out easily you have an air leak. you can adjust a freezer door by loosening the hinges, pushing the door into place and re-tightening the hinge.
This is a symptom of air leaking into the freezer. The most common place is around the door. Check the door really good to make sure something is not obstructing it from closing all the way, it may be closing enough to satisfy the ajar alarm but not enough for a bit of moisture to sneak in. Look for tears or breaks in the seal. If you put a bright flashlight inside the freezer and close the door, turn off the lights in the room you may find a leak that way.
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Dear it depends upon the temperature settled, but i think that the problem is with the gas leakage in your freezer, thats why it cooling is geting week, so , it is better to call a mechanic to check it properly.
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
