There may be a short cut because of the humidity. First dry it.
Check the polarity of the batteries while placing in the item.
1. Remove the batteries.
2. Check ithe item for a short cut and continuity of the electronic card. Use multimeter to check this.
a. Full size movement on the screen MEANS Short Cut
b. Minumum size movement on the screen MEANS Connections are Normal
c. No movement on the screen MEANS Discontinuity on wiring
Did you drop the item? If at least one time you have dropped it then this is out of your any user to fix it. So it should be brought to the nearest Authorized Service Center.
Make sure that nothing such as your hand or finger is blocking the laser emission aperture and laser detector.
Make sure that the laser emission aperture and laser detector are clean. Clean them if necessary.
Make sure that the target shape and condition is appropriate to reflect the laser beam.
Otherwise, you'll need to contact Nikon service center for repair.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
My Nikon Lazer 500 range finder stopped registering a distance, I replaced the battery, cleaned the 2 lenses and still doesn't work. Any suggestions for me to fix this myself?
