Square D Co. HOM130 Circuit Breaker Logo
Posted on Jun 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Switch stuck in trip mode
My bedroom & bathroom are on same breaker switch and i have no power going to either. I tried to reset switch by going off then on , i turned main power switch off then back on, i replaced the switch , with all that done the switch continues to stay in trip mode. The switch is a Square D HOM .
Anonymous
Level 3:
  • Master 396 Answers
  • Posted on Jun 25, 2010
Anonymous
Master
Level 3:
Answers
396
Questions
0
Helped
157372
Points
1224
The reason why the breaker stays tripped is a result of a direct short. Unplug every electrical device plugged into an outlet in both rooms and try the breaker. If it stays on, individually start plugging in each device until the breaker trips, that is the defective device. If the breaker stays tripped, start checking wall outlets for short circuits with an ohm meter. If you did not find a short, check your hard wired lamps and appliances for shorts. If you did not find any shorts the only other problem is a shorted pair of wires in the wall or ceiling. You will need to disconnect any hard wired lamps and appliances and check for shorts between individual pairs of hot (black) and neutral (white) then hot and ground. I have a short circuit finder, but you do not need one because the technology is not perfect and you may have to manually check for shorts with a meter anyway which never lies.
Ned C Cook
Level 3:
President:
  • Master 3,433 Answers
  • Posted on Sep 15, 2014
Ned C Cook
Master
Level 3:
President:
Answers
3433
Questions
0
Helped
1438188
Points
9966
Hello; Unplug everything, then try resetting GFI. iF IT DOES NOT RESET, YOU KNOW IT'S NOT AN APPLIANCE.ccHECK UNDER THE KITCHEN SINK MAKING SURE THE DISPOSAL OUTLET ISN'T WET. SINK AND PLUMBING LEAKS LOVE THAT POORLY PLACED OUTLET. tHEN CHK ANY OUTSIDE OUTLETSFOR EXPOSURE. aGAIN, IF NOTHING IS FOUND ATTEMPT RESET. iF IT RAINED RECENTLY IN YOUR AREA, LOOK FOR SIGNS OF AN EXTERIOR OUTLET BOXES HOLDING WATER.
gOOD lUCK AND BE PATIENT, iT JUST HAS TO BE LOCATED.
Ned.
Anonymous
Level 3:
  • Master 843 Answers
Anonymous
Master
Level 3:
Answers
843
Questions
0
Helped
394461
Points
2420
You said you "replaced the switch". Do you mean you replaced the breaker and the new breaker will not go on? If this is the case, then you have a short circuit in the wiring, or in the bedroom or bathroom, and the breaker is doing it's job. Have any recent changes been made in the outlets, switches, or fixtures in these rooms? Any recent nails put into walls? If not, try unplugging everything in those two rooms. You will have to find the fault by a process of elimination.
  • Anonymous Jun 25, 2010
    I also found this description of the HOM type breaker. It may give you some clues---
    Single Pole Arc Fault HOM Designed to detect arcs that are caused by damaged - aged or improperly used wires or cords and to disconnect the power.Arc faults can not be detected by standard circuit breakers and fuses.Square D Arc-D-tect AFCI3 will fit into existing Square D loadcenters.
1helpful
3answers
Square D circuit breaker in a home fuse panel and I have already replaced the breaker with a new one.
i strongly recommend that you get in an electrician to investigate the problem
from your description of the amount of power required from your circuit breaker I would consider that there are to power wires from the back of that unit
one circuit to run half the points and another wire to run the rest
If only 1/2 are working, I am thinking that one of the wires at the back of the breakers is loose or come undone/broken and that will require the services of an electrician
To further explain this line of thought, each circuit in a house is designed to carry a maxim of 10 amp total (wire current capacity) so that with all outlets in operation the maximum current is 10 amps
if the required current allowed exceeds that the electricians break the numbers up so that a second circuit is employed again up to 10 amps max
if again there was a requirement that exceeded the 20 amps ( circuit breaker amp) a second circuit breaker would be installed and a 3rd circuit and so on
1helpful
2answers
Why does the breaker keep tripping on this 2.0hp exhaust fan motor
Christopher, motors starter/capacitor could be faulty, wire circuit/breaker could be insufficient. motor could be faulty or wired incorrectly. Have motor checked out and ensure you are wiring correctly.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LEESON Electric Motor Trouble Shooting Chart
Motor trips breaker Why
http://www.garagejournal.com/forum/showthread.php?t=256105
2answers
No power in back bedroom
Locate your circuit panel, and check your fuses/circuit breakers.
Maybe breaker tripped?
To reset, remember: All the way to OFF position first, then flip towards ON.
1helpful
3gfi plugs on a coachman Aurora do not bathroom bedroom work fine.
sometimes, a GFI will be controlled by another GFI. Did you "reset" the GFI ( if there is one ) in the bathroom? You have to find out where
The wires in the dead GFI come from. Electrical panel....circuit breakers. Did you flip each circuit breaker off then on to reset them ?
Do you have an electrical meter ? let me know then we will go from there.
2answers
Crest audio cpx1500, one channel not working ,
The breaker is stuck because there's some internal circuit problem on the amp. Something is tripping it i.e. a wiring short or blown speaker driver if they're connected, or an output transistor has blown.
Fix the problem BEFORE trying to reset.
Switch all off. Disconnect your speakers from the power amp. Switch the amp back on. If it will reset now then you have a wiring or speaker issue. If it won't reset then the problem is something broke in the amp.
Transistors are part of the circuit board. They're soldered in and also bolted to heat sinks. Not a DIY fix unless you know what you're doing. Take the amp to a repair shop.
2answers
MY WIFE HIT HER SHOULDER ON THE SWITCH BOARD IN THE BATHROOM AND THE POWER IS GONE in the bedroom and bathroom. Other parts of the house are fine except our bedroom and bathroom. ALL THE MCBS ARE ON. SILL...
Flip each breaker all the way off and then all the way back on.. If that doesn't fix the problem, look for a tripped GFI (go around and press the reset button on any outlets that have the buttons "test" and "reset"). If that still doesn't work, you should probably contact an electrician.
2answers
Joecoolvette, The circuit breaker I was talking about is not the old fuse type. The power outage problem has affected light and receptacl circuits entirely in my bathroom as well as partialy in my...
I would first remove all of the loads from the circuit including taking out the bulbs
Switch everything off and reset the breaker, if it pops then there is a dead short on the wiring due to scrape type flash connection.
It is also feasible that the breaker has gone faulty because they too have a life cycle which shortens every time they are reset
On your breaker board do you have the facility to swop over the same breaker from another circuit.
Regarding tool I assume that you are buying an insulation tester such as a Robin or a Megger?.
In the mean time If you are a competant person I would suggest that you remove the Hot wires from each of the fittings tape them off and mark up where they go back and then reset the breaker, if the problem persists then it is either neutral to earth or a damaged cable
Isolation and testing is the only way forward
I have a circuit breaker that is intermittent
It is unlikely that those temperatures would cause the circuit breaker to shut off and come back on intermittently. (If the breaker trips it has to be reset manually.) It is possible that the breaker is defective internally or that there is a loose connection in the wiring. If you are not knowledgeable about electrical work you should have an electrician check it out for you.
2answers
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Top Square Electrical Supplies Experts
CJ Rock
CJ Rock
ADMIN Eric
ADMIN Eric
Are you a Square Electrical Supply Expert? Answer questions, earn points and help others
