Question about Frigidaire GLTF2940ES Front Load Washer
Mold around the front gasket
I have owned a FRIGIDAIRE front-loading washer (GLTF2940FE1) for 2 years, and the machine has developed a layer of mold on the front gasket by the door. How do I remove this mold without damaging the gasket, and is there a way to keep the mold from returning? I also guess there is mold in other parts of the washer, and this may be part of the problem. I rarely use bleach to wash my clothes. It help the problem if I were to use bleach more frequently?
6ya staff
SOURCE:
Anonymous
SOURCE: clothes are being stained by straight lines like from a pencil
keep the rubber gasket really clean! had the same problem and reg cleaning worked...no more brown lines!
Posted on Mar 18, 2009
Anonymous
SOURCE: Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Posted on Apr 12, 2009
Anonymous
  • 97 Answers
SOURCE: MOLD
Hello Friend, Sounds to me like you have a problem with the quality of your water supply going into your washer. Water quality could be a possibility. If the water contains alot of micro-organisms this could be the problem. When you are not using your front load washer the door remains closed trapping in moisture causing mold and mildew to grow. If you just repeat the cleaning process once again with bleach you should'nt have this problem anymore if you leave the washer door partially open when not in use. Happy to help, Tim.
Posted on Jun 25, 2009
Anonymous
SOURCE: Describe your Frigidaire GLTF2940FE1 Front Load
Run a cycle with just bleach and detergent, no clothes.
Posted on Mar 29, 2010
marka19
marka19
  • 1430 Answers
SOURCE: mold on rubber gasket
The door seal need to be pulled almost inside out to be a able to thoroughly clean it. I usually use a 50-50 mix of bleach water but other cleaning products like oxyclean may work better. After cleaning run a load with no clothes in it to remove any residue. Now if the mold has gotten deep into the rubber and still looks blackish after cleaning it will get moldy real soon and replacement will be the only solution. The key is from day one to leave the door open as you do and also wipe the door seal with a towel after each use. Not to defend frigidaire but most of the other brands have the same issues, some worse. If you need to replace the door seal or if the wire ring pops off when cleaning here is a link that should help http://appliancehelponline.com/washerdoorseal.html
Posted on Jul 13, 2010
Testimonial: "Did not know we could replace the seal. yes, the mold has stained the gasket. Thanks, will check this out."
How do you get rid of mold smell in washing machine
Hello friend, thanks for your post!
I understand that you have a mold smell developing inside of your Frigidaire washer. I would normally recommend using a clean wash cycle with either one cup of bleach or one pouch of Tide Washing Machine Cleaner. If you do not have a clean wash cycle on your washer you could also use hot water and a regular cycle with a cup of bleach to clean out your washer.
You should also check over your gasket to assure there is no mold buildup, if you do locate mold inside of your gasket you can use bleach to help get rid of any residue. I hope this information is helpful. -Matt
Sep 25, 2014 | Frigidaire Washing Machines
The gasket around the opening from the front door gets nasty. How do I best clean this?
a little bleach in water works well and kills the mold. be careful not to tear the gasket, easy does it. a old tooth brush also helps. some of the spray cleaners also work
Feb 04, 2011 | Frigidaire ATF6000ES Front Load Washer
Something has to be done about this issue. Our Frigidaire washer is about two years old and the gasket is FILLED with mold. I have tried everything to clean it and now I am starting to worry about our...
Have a smelly HE front loading washer ?!
Need to get the mildew smell out of towels?
Have slimy black mold on the door gasket ?
Mystery smudges, spots or stains after washing
TechnoFresh™ is the Answer!
It's Guaranteed to Work!
or your money back...
Patent Pending
_______________________
Returning Nu Fresh Customers:
Nu Fresh is now called
TechnoFresh™
TechnoFresh™ is an even more effective formula
Nov 23, 2010 | Frigidaire ATF6000ES Front Load Washer
How do I clean the front door gasket area?
Here is a tip that I wrote about that problem...it tells you how to clean your washer and also how to prevent it from coming back...
I will also include a tip I wrote on washer maintenance...
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
http://www.fixya.com/support/r4312694-washing_machine_maintenance
heatman101
Asker's Testimonial " heatman 101 Just wanted to say thanks for helping me with the mold
Apr 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Mold build up around ribber gasket . Heavy, black and hard
Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
May 28, 2009 | Washing Machines
Is there ANY way to remove the gasket from a frigidaire GLTF2940ES front load washer???? It is absolutely covered with mold, it is moldy underneath, my clothes smell disgusting!!! I want to clean...
yes there is way
How to remove and replace the drum gasket on the Frigidaire -Front Load Washer with notes on tub bearing replacement and inner drum replacement....
for all the detailed instructions
click the link directly
http://www.applianceaid.com/417_Frigidaire_washer.html
hope this helps
May 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washing machine collects water behinf door seal
your washer is a great washer BUT you Have to wipe the silly gasket all the time and leave the door open to let it vent and dry I deal with this all the time and no they dont tell you this when you buy them (they Should) but they want the sale then its your baby.I do warranty work for all the name brands and I see this on all of them good luck
Dec 17, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
90 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
