What is E2? Treadmill starts and then stops showing Code E2. Can anyone help? the treadmill is a Image 10.6 Q. Thank you.
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Always important to make sure your first step when something goes wrong is to check out the manual. Read the link below! http://www.vsguides.com/weslo-vs-golds-gym-treadmill
Ok guys so mine was showing the same code. E2. I decided to open the cover and after looking at it for a few minutes. I ended up noticing this wire loose. So I unplugged the wire all the way and connected it back and now it's running. Give it a try guys all I need was a small screw Philip screw driver hope this helps .
- Juan c.
Bh fitness treadmill problem
what is error E2 on a Body break treadmill model 1611A35?
- Juan c.
