Question about Mitsubishi WD-60735 Projection Television
My tv has lost it brightness you use to be able to see the tv really good but now it looks dark and i have tried to adjust the color and the perfect colors on it but it is no help i think my kids push the reset button on it what can i do and i dont know my pin for the lock mode
  • Mitsubishi Master
  • 8,617 Answers
Sounds like the small front mirror needs cleaning, as that will make the pic appear very dull looking and dim brightness.
Posted on Jun 27, 2010
Voire 46" plasma tv- best color settings, to much white
The proper way to set flat screen tv's is opposite of old school CRT tv. First, find a movie with dark scenes and pause on a really dark part. Now set brightness only high enough to see some detail - no more. then go to a really bright scene and set contrast just high enough for good brightness. You may need to go back and forth a few times to get good setting.
Dec 21, 2013 | Toymax Viore 42 in. Plasma TV
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Picture adjust
Put it in the custom mode.Put the contrast to the max.Everythings else in half in the middle.
Colors maybe less.Now u have the desire adjustment?
Aug 19, 2009 | Televison & Video
TV is dark
you can fix this problem. remove your tv back cover, there is a part called Flyback. attaching to picture tube. it has two probs for adjesting focus and brightness.adjust your brightness porbe.
Aug 16, 2009 | Televison & Video
Dark screen on my headrest tv
its defective, need to be repaired or replaced
May 29, 2009 | Car Audio & Video
Brightness and color
It really depends on what YOUR eyes are pleased with - if 50 looks good to you, that's where it should be. It seems like you might be afraid of messing up something - don't worry, you can't hurt the TV by adjusting the customer controls :-) You might try a little experimenting - kicking them up to 75 might give you a brighter and more pleasing picture. I've been a TV technician for years, and I generally like the brightness and contrast up almost to the maximum (I like a bright picture as opposed to a "warm" one), with the color and hue adjusted for an accurate reproduction of facial tones. But the bottom line is what YOU want - feel free to experiment, you can't hurt anything as long as you don't start taking out screws :-)
Jan 02, 2009 | Toshiba 36AF41 36" TV
My darks are to dark on TV
what happens if you adjust the contrast or brightness?
Feb 21, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PROJECTION TV Phillips 9P6031c103
this is what convergance looks like;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
if pix is dark their is 6 adjustments knobs in the front of the tv under the screen and behind the plastic cover. the top three are the brightness bottom three is focus.
Nov 24, 2007 | Toshiba 53H71 53 in. Rear Projection...
Edge Enhancement Option Disabled...
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
Oct 05, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
Mitsubishi WD-60735 Projection Television Logo
345 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
