Hi just read your posting.Error code 49 means your cold water valve is faulty,The valves are located under the top panel.Do you help in the step by step testing of the valves?If you do please reply and I can help you rectify this problem.
Yes a step by step would be helpful
Hi harry just found your posting.Now the 1st thing to do is to remove the 2 screws on the top panel.Once these screws are removed then slowly lift the top panel away from the machine as it will have a wiring harness attached to it for the display module.Now rest the top panel on the lid with the wiring harness still attached to the display module.Look to the left of the brown computer and you will see the water valves.On some machines there will be 2 valves and on other models there will be 4 valves.How many valves has your machine got and what color are they.They might be blue in color.Please reply with additional information and I will guide you throe the rest of the repair.Looking forward to your reply.
Hi I am having the same problem as everyone else it seems - error 49!! I have read the help form luisa but need further help if any can advise - I only have 2 valves but dont know where to go from here. Leanne
how to sove the problem for a code 49
