Question about Whirlpool Duet GHW9150P Front Load Washer
What does problem f2 mean
Clothes are not spinned
    President:
  • 1,561 Answers
the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Take care.
Posted on Jun 27, 2010
2 Suggested Answers
6ya staff
SOURCE:
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: washing machine won't spin clothes completely
Hello, Welcome to FixYa. To address your question, the F21 indicates a long drain time has been detected. What that usually really means is the pump filter is clogged. Click on the link or alternatively copy & paste my link below and you'll find detailed guide on what to do. Good luck. http://www.fixya.com/support/t7710198-code_f02_washer_will Regards, Macmarkus :)
Posted on Mar 30, 2011
GE washer wle4000b1ww won't spin with clothes in it but will spin when empty.also the spin light blinks,I have checked the belt and the belt is good please help mother of 2 thank u
Normally, when a washer will spin without cloths, the washer is doing all the basics correctly. But when you add cloths, which means adding weight, the washer will not, then its a suspension rods issue. The suspension rods absorb the weight and allow the washer to spin.
May 25, 2016 | GE Washing Machines
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Washing machine won't spin clothes completely always have to run spin 2nd and sometimes a 3rd time...code says F2 I don't know what that means
Mar 30, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 error
f2 means the unit is draining to slow...you need to clean your pump filter...if you need help with that post to onthejob
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 problem
f2 is usually and indication of drain problems usually something in pump ..have seen impeller on pump shaft come loose and freewheel..remove pump completely 3-4 screws hold pump motor to housing remove them try turning impeller if impeller spins free replace pump ..impeller will usually have some resistance when turned by hand..a free spin on impeller indicates it has come free of motor shaft
Aug 28, 2008 | Kenmore Elite 45986 Front Load Washer
My whirlpoolfront load duet washing machine
"F02" is a Long Drain error. This could be caused by a number of things. The likely suspect is your drain pump. Please click on the following link for instructions on how to diagnose and repair this problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
I hope this information helps you. Please post back if you need further advice. Go to my profile and use the "Ask Me" feature for a quicker reply.
Jun 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
152 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
