The first thing you should do to fix this error is - if you're using Windows 98 or 2000 - to use the 'registry checker' facility. This is done by loading up the "Run Console" with CTRL + R and then typing "registry checker". If the registry is intact then this will not be a problem. On later versions of Windows, you should use a 'registry cleaner' program to perform this task.
If you have XP, Vista or Windows 7, you should first download a registry cleaner from the Internet and let that scan your system. It will look for any registry errors on your PC and then fix them, which should fix the 1402 error in the process. To use one of these, you need to download a registry scanner program and then let it scan your PC. It will identify all the damaged parts of Windows and should fix them. And if one of these registry errors is causing the 1402 error then a quick restart after the registry scan should enable you to install Office or the program you wanted.
If that method did not work, you should try using a different user account, or creating a new user account, to install the program onto. It's often the case that user accounts will become corrupted for whatever reason, blocking access to the registry. This causes the 1402 error because it means that the program cannot access the files and settings it needs to create when it's being installed. You should try creating a new administrator account and then installing the program on that.
It's a security related error. You either don't have permissions to install it because you are not an administrator on that machine or else you need to reset permissions on some registry hives.
in short this means the EGR (Exhaust Gas Recirculation valve is blocked, most like the passages in the intake are carboned up, go to the link below for full diagnosis and testing for this fault code P1402
I can't find the 1402 battery listed on the Makita website. What is the tool catalog number and I will find you a bettery that way. You can buy online at Makitatools.com and also they have a locator to find one locally that you can use. Let me know if you need more assistance.
This is a problem caused by the security settings on your computer. The only way to correct it is to do some registry editing. The link to the Microsoft Knowledge Base is - http://support.microsoft.com/kb/236592/en-us this gives you step by step directions on how to fix it!
